2012 C300 ESP code C198400 Fault status during valve calibration
Received 3,370 Likes
MY'14 W212 M276 3.5NA @55kMi
hard fault
You have a confirmed ESP fault.
Where to start is with the guided test an live data using your tablet scanner.
Being valve related suggest it is not the pump motor but the loose circuit board pins - Unless your up for basic soldering of electronics you'll need replacement ESP + programming/cloaning.
KKA (04-14-2024)
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
Received 1,602 Likes
Why were you calibrating the ESP?
