M272 exhaust manifold- cleaning and install
I've been working on other services but am going to read through this thread in detail when I get to this.
Funny how clever your nozzle + boroscope trick is; I was thinking of doing the Exact same thing except 3D printing a jig for a mirror on a wand that also holds the straw. Your idea is way better hahahaha!!
Amazing that you are able to get to the bolts like that! I have an M273 in my W212 (2011 E550) and wonder how the layout is different. Mine seem extremely difficult to get to.
The nuts conundrum is very interesting. I noticed the exact same details. EPC has both listed for the M273 for my year make model; no noticeable difference in the nuts but definitely in availability and price. I see now that you have the V6 so the difference in access makes sense.
I like taking photos so I can view them up close on the computer and really see what im dealing with.
In trying to search for the "best" rust penetrating fluid I keep seeing people claim that heat is the best. The is no way i can fit a big torch in there but remembered I have a small butane torch I got for soldering wires together. I have to get some more butane to try it out but I went in the engine bay and I can reach the nuts with it. I think this will be good to have on hand.
Right now i'm searching for a good 10mm wrench. I was playing around with the new manifold and realized I cannot fit my 1/4" ratchet on the two bottom middle nuts, the ratchet hits the manifold. And thats with a shallow socket. It fits when I put my swivel extension on but it seems like a sharp angle I prefer not doing. I did order a 10mm six point swivel socket that may work better. But I tried my small 12 point 10mm wrench it it looks like thats a better way, but I want to get a 6 point wrench if i can.
This is where the ratchet ends up if i have the socket straight up and down. Wont fit over where the nut is.
If I tilt the ratchet to fit then the socket isnt on flush.
Wrench will fit fine.
Swivel adapter works, but I dont like the angle. Plus I think the engine mount will be in the way at this specific nut for this to even work.
I'm getting better using the borescope. I turned the camera on then I taped the straw extension so its at the bottom, makes it easier to find the orientation. One thing I noticed with the Liquid Wrench is it seems to evaporate over time and i couldnt see any left on the studs earlier today. I sprayed PB Blaster just now so i'll see how that looks tomorrow. I'm going to start wire brushing the studs to clean them up, should have been doing that from the start.
Heres the top of the header bolt, the bolt on the inside that I cant even see without the borescope. Does a good job of being able to hit it with penetrating fluid. The picture on the borescope screen is much better than this photo shows. I took the photo using my phone.
Have you considered a ratcheting wrench that has a pivot? Maybe one of those wrenches that has an S shape to its body?
I hear you regarding either fully committing or not. Maybe whether you can get each nut to break loose or not could be how you decide which path to go.
Have you seen this comment? Maybe a new penetrating fluid you've considered: https://mbworld.org/forums/e-class-w...ml#post8579663
The 18" flexible ratchet contraption really is handy. Received the 1/4" 10mm socket assortment set so was trying them out to see how they fit. It has a 10mm swivel socket that has a hole in the socket part that allows the stud to pass thru, though I may open it up a little more with a drill bit.
I had the ratchet on, plenty of penetrating spray, and kept trying to loosen-tighten-loosen-tighten then finally the nuts started loosening. The didnt break free, instead they just started slowly moving. I wasnt using too much pressure. The ratchet itself has quite a bit of flex. I feel so good right now that they are coming out. I couldnt tell if the nuts were coming off the studs or if the studs were coming out. I tightened them back up since i still want to drive the car and dont want the exhaust leak getting worse due to loose nuts.
I'm thinking the bottom nut closest to the engine mount will be hard to reach with sockets so I ordered a 10mm offset wrench that should fit anywhere. If I dont end up using it ill just return it.
The 5-piece set was only $7.97 on Amazon but I guess I bought the last one. They have the same set just under a different brand for $11.67. I like the swivel socket because it is much shorter than using my swivel adapter on a 10mm socket.
And for the top rear nut i have to remove the air box to be able to reach down and guide the socket on. Plus the sockets tend to get stuck on the nuts so I have to be able to reach down and yank them off.
I've had some luck using tooth-brush type wire brushes to hit the threads and clean them up some.
Top Front Nut:
Top Middle Nut: Can see the head of the ratchet just clears the top of the manifold using the deep socket.
The extra-long ratchet has two joints in it to move. Then I have the 10mm swivel socket plus a set of swivel adapters if needed. I'm trying to squirrel together every single tool i'll think I may need.
Realized I will need a way to remove stuck/broken studs. I have a set of vise grips that should work though I just ordered two stud extractors. I think the studs are around 6mm, my order from FCP should be delivered today so I will know better when they get here so i can try everything out. I ordered a 1/4" drive extractor and a 3/8" drive extractor. The 1/4" says it goes up to 6mm, and the 3/8" says it does 6mm-12mm. Some of the reviews for the 3/8" says it wont fit 6mm studs, so who knows. Better to have both on hand.
Going to work on the nuts some more later today, see if I can get the rest loosened. I think between the PB-Blaster and the Liquid Wrench those are dealing with the rust pretty good, just have to keep wire brushing everything to knock the rust off so they can penetrate the threads better. I think the loosening-tightening action is helping.
Also wondering if there is enough space to remove the manifold once unbolted, probably wiggle it out to the left of the alternator.
Still thinking about the nut at the engine mount. I looked around for what the engine mount looks like and seems there is a notch in it on the left, probably have enough room to fit an offset wrench and get it off that way. I'd love to hear how anyone else removed it. I think that nut is where I put the red dot in the photo of the mount below.
Received the parts from FCP and looks like I ordered the correct parts. Looking at the studs and how small they are im glad I ordered the smaller stud remover. Also got a new smooth idler pulley, the one in the car sounds very loud when using my stethoscope on it. Wonder if it will make a difference.
I've had that pulley off a few times before and I still forgot about the small washer on the back side and almost didnt even see it. Took some photos even though its a pretty simple job. I still have the small pin that came with the belt tensioner so just used that to hold it open, tension off the belt. 17mm socket and small extension on a breaker bar to move the tensioner. E14 socket to loosen the pulley bolt then remove it by hand while holding the belt so it doesnt move. Dont have to remove the belt at all. Install new pulley and remember to install the washer, torque the bolt to 25nm/18.5 ft lbs.
I drilled out the 10mm swivel socket so now the stud can pass thru it. Worked my way up to a 1/4 drill bit and fits fine now.
I'm going to start a new thread when I start the work to show what I did. I'll try not to ramble on and on as much.
I started the car up and the exhaust leak isnt really any worse.
Not sure what to to do now. Bring it to Mercedes and have them fix it? Or keep going and deal with things as they come? this was my nightmare. Im looking at the break and it appears the stud snapped out past the manifold flange so there should be 1/8-1/4' left sticking out once the manifold is removed.
My plan, if I were to attempt this myself (extremely unlikely after seeing your journey), would have been to take it to a German mechanic (one that specializes in Mercedes/BMW) and have them take the reigns.
If you take it to Mercedes they're going to find an issue with your suspension and try charging you a kidney. I don't trust the dealerships but that's me.
Are there any independent Euro mechanics around you? Maybe an exhaust shop?
Seems it's drivable so you wouldn't even need to tow it.
You've already done 80% of the most difficult part of the job.
I wish you were my neighbor. I'd gladly give you a hand and bring a 6-pack.
Watching you do this I realize I'm almost definitely right about the "working space" in my V8 engine bay being dramatically more tight. I don't think this is a feasible job for me and wouldn't have been able to decide that without watching your incredibly well-documented journey.
You have probably the same drive, problem solving acumen, and resourcefulness that I do, but with a slightly less difficult scenario due to the difference in engine.
Time for me to start saving up for a shop visit. First one in so many years.
I have a set of old Sears vise grips to try. I wanted to see how easy the nut turns off the broken piece of stud and it turned fairly easily using vise grips and 10mm wrench.
Surprisingly the the header bolts are easy to reach, I remember one person writing in saying he couldnt seem to get the inside bolt so I was afraid of that one, but they are right there and can get them with an extension. 13mm socket. I sprayed everything down again with some Liquid Wrench just for fun. Wondering how i'm going to get that exhaust out of there, there is a cross member in the way so it wont just pull straight down, may have to get creative especially with the car on ramps.
I see there are two O2 sensors in the section so instead of trying to remove them which I cant reach anyways I traced the wires and the plugs are up near the maf sensor. In the photos can see the oil separator breather hose that goes to the throttle body. Just have to remember ones green and one is black. Its why i'm taking alot of photos. Can look thru this thread when i'm putting things back.
I saw the broken stud close-up and to me it appears there should be a decent amount of it sticking out of the head to grab on to. I ordered some reverse thread nuts for 6mm bolts, wonder if i can put that on the stud and remove it that way?
Other than that one manifold nut I haven't really broken anything yet so the car is still driveable. Try again tomorrow and see if i can get any progress done.
Looking at the piece of broken stud/nut I dont see any of the nuts coming off from the studs, its either the studs come out with the nuts or the studs break.
Heres the new parts. The new bolts screw in easily by hand up until the very end of the nut, then it gets tight.
I pick up the car and the check engine light it on. The passenger side engine mount shield along with the front drive shaft shield are in a box in my trunk. I get home and im now going thru the entire car. They removed the exhaust it appears and put a basic clamp back on, no big deal ill order a new clamp. The twi wires for the O2 sensors are all tangled and not secured, one was very close to rubbing the drive shaft. One of the air box metal clamps is missing, not sure how that happens since i cant even budge the other ones.
i was able to clear the codes expect for one, having to due with the abs. Hopefully its just from low battery or it being disconnected. Im charging the battery right now. I'm also ordering a new air box clamp and exhaust clamp. Im going to order an engine mount wrench to double check the mounts are tight.
Looks like they were able to get the two rusted header bolts out, but now there are nuts and bolts in there, instead of the affixed nuts that belong on the exhaust manifold. i have no idea how they even got the nuts on. Im trying to fish my hands down to re-secure the O2 sensor wires out of the way.
I am so happy they didnt end up pulling the engine and only seemed to screw up a few things. The exhaust seems louder now a bit since the header bolts dont appear on tight, that joint must be open. But thankfully also i looked and they didnt break off any more manifold nuts/studs.
Think i'll take it in to Mercedes and see what they say, i'm curious if they say the engine has to be pulled. or would removing the head be easier/less work? i dont know.
I am blown away at how that shop left my car. When I picked it up i noticed the cover for the radio was open which I know for a fact was closed when I dropped it off, I never have that open so I think that is very strange. Not only did they not put the heat shields for the engine mount and front diff i cant find the bolts for them anywhere.
Now im just ranting. Thinking how i'll have to go thru the car over again tomorrow to see if I missed anything they screwed up. No way would I ever go back to them, not even going to bother asking for the missing bolts and air box clamp i'd rather just get new ones.
One EXTREMELY positive thing is they didnt end up pulling the engine, it would probably never run right again if they had. I still question if the engine has to be pulled to do the job. And if it does have to be pulled I might as well have the drivers side manifold and gasket replaced since im thinking the nuts attached to that manifold will get mangled. I'll have to call Mercedes and see what they say.
When I was under the car previously I noticed a metal brace going over across the middle section of the exhaust and remember thinking it will have to be removed to drop that section of exhaust pipe, except the bar ran underneath the two side plastic undertrays. Was just under there and saw what that shop did, they just cut out the undertray in pieces to remove the bar. I am completely outraged at the hack job that place did. I also think they put the two O2 sensors back in the wrong places, switched them.
The metal shields for the front diff and engine mount they didnt put back or include the bolts to install them:
Odd that would cause only one code, I would think both O2 sensors would throw codes if they were switched? The one installed at the bottom (which should be #1 at the top) appears to be bent near the wire, wonder if its just broken now?
I'm taking it to Import Autowerks which says it deals with Mercedes and BMW and im seeing all positive reviews. I'm really hopeing they can figure it out and get the job done. We shall see I guess. If they do get it done i'll try and ask them what they specifically did so I can let everyone know.
I tried to figure out how that last shop got the two header bolts out and I think they maybe cut them out somehow. The nuts that are attached to the exhaust manifold dont look like they are there anymore and instead just a regular nut and bolt is there, very odd.
Now i'm stuck trying to track down new undertrays for the sides that the shop cut away. New they are around $160 each, finding some used for around $100 each. Maybe I should try local salvage yards since its the shipping costs that make them cost so much. I double checked and sure enough some of the bolts werent even tightened all the way. Im seriously going over the entire car checking EVERYTHING. The wrote an R with an arrow on one of the braces they clearly removed, its on the passenger side so the right side but the arrow is pointing to the rear of the car?
I was searching for all the bolts to re-install the two metal shields and they appear to all be M6 bolts just all different lengths. I ordered a bunch of M6x12 bolts (910143006000) since FCP had them available. If the bolt ends up being too long I figure just add a washer and call it a day. Or even get bolts from the hardware store, I usually only like using Mercedes hardware but for these shields I dont think it really matters as long as they are back on. In the parts diagram for the engine mounts they show a picture of a different engine but the part #'s seem to be correct for what I have.
Got the new airbox clip which i really couldnt wait to get, the air box felt loose with that one missing and it wasnt seating well over the maf, wasnt lining up and i had to reach down and force it on.
My appointment is tomorrow so hopefully I can get some answers if they can install the exhaust manifold. Fingers crossed.
Trying one more time to remove the O2 sensor, I dont feel comfortable driving around knowing they are switched, im paranoid it may mess up the cat some how? Such a project just getting the car up so i can even fit under, and its just barely.
I took alot of photos of my car when working on it before, now after this mess im taking even more. Would be nice to have proof the plastic undertrays werent cut away prior to that shop getting ahold of it but dont think I have any photos specifically showing it. Should have taken a photo of the mileage too, soon as I started the car the low fuel light came on and I know I had 1/4 tank when dropping off, now its much lower. Did someone take it home and drive it around? The cover for the radio was open when I picked the car up and I never have it open. I had some money stuffed in the arm rest I keep there for emergency which I made sure to remove prior to dropping the car off thankfully.
Tried to fit the metal shield for the engine mount on but it wont fit, must have to be fitted from below when the exhaust pipe is removed. Received some M6 bolts that will hopefully work to re-install both metal shields.
