Esc Light, along with zero turn signals, cruise control, steering wheel adjustment
2010 c300 sport 4matic
I have a problem when my 2010 c300 sport 4matic, in which when I hit bumps, railroad tracks, ect. Esc turns on, zero turn signals, no cruise, nore steering wheel adjustment. But since Ive bought my w204 almost a year ago it had a SRS airbag light that comes off and on and a Mercedes dealership did nothing to resolve the issue. I still have hazard lights and I can only “adjust” the steering wheel with the memory seats, Ive seen people with the same car have problems with that clock spring and or steering column switches, my local german auto house thinks that side marker lights that have been installed after the problems even started, and I believe thats they are wrong, any advice or suggestions.
Received 3,372 Likes
MY'14 W212 M276 3.5NA @55kMi
It sounds like your Steering Column Module has stopped being nearly reliable.
Use a good MB specific scanner to retrieve all fault codes for your troubleshooting.
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
Received 1,611 Likes
You have many issues. BUT the SRS light can be caused by a broken wire in the seat belt latch. That is very common among the W204. As Cali said, get yourself a proper scanner. You will need it to diagnose your specific problem, as well as, reset your airbag light. Get a LAUNCH Creader Elite 2.0 BENZ.
