2009 C350 Battery Drain
Any idea would be greatly appreciated, at this point! Also, anywhere that I can find wiring diagram, to at least check what amperage goes to what fuse box.
Speaking about fuse box, my inside cabin one has only two (2) fuses 116 and 130. pretty sure 116 is driver seat module, but no idea of 130 and there's voltage there.
TY!
Heres a link to the fuse box diagrams: https://fuse-box.info/mercedes-benz/...uses-and-relay. Says 130 is "Spare".
Attached fusebox pic.
E=TimC300;9028621]Have you scanned the vehicve with a Mercedes specific obd scanner? It may tell you the fault.
Heres a link to the fuse box diagrams: https://fuse-box.info/mercedes-benz/...uses-and-relay. Says 130 is "Spare".[/QUOTE]
