M157 in a c300
Old Oct 10, 2024 | 05:50 AM
MercedesC999's Avatar
M157 in a c300
I'm currently working on pulling the stock v6 out of my c300 it's got some weird fuel tick I've never heard of before so I don't want to touch it, I've found a cheap m157 car (5.5l biturbo) that has the ecu (all the pins match up to c300s ecu plug in)
It also has the ignition switch and key (as I'm aware I would need for this to work) the c300 and the cls63 (doner car) have the same transmission so I was wondering if the manual transmission that comes in the c300 would be able to hold power up to 750hp because I would prefer it be a manual swap as well, I understand it is direct bolt on to the transmission, motor mounts, and ecu and all the other electronics (ignition switch, ESL simulator, etc) Mercedes still uses the same ones in base models so it's the same part so they will also be plug and play, however, one issue I ran into was that the cls63 from 2012 has a whole touch screen module to change from sport, track, comfort all that good stuff and the 2008 c300 uses a 2 function switch that only allows comfort and sport, so would I need the entire Guage cluster and head unit out of the AMG too? And is this all going to be as plug and play as I think?
Old Oct 10, 2024 | 12:42 PM
JettaRed's Avatar
Veteran: Army
Please identify the year and model of your car, and where you are located in your profile to be displayed with your posts. People will help if they can, but don't make it tough for them to figure out what you have.
