Help me fix this please !
Old Nov 30, 2024 | 06:34 PM
c300mb's Avatar
2013 Mercedes C-300 4matic
CODES : P0507 P2279
-LOUD SQUEALING SOUND AFTER WARM UP
-NOISE WILL GO AWAY WHEN OIL CAP REMOVED (feels like high suction at oil cap)
Should I replace the centrifugal cover behind the engine passenger side ? Easy job
or should I remove entire intake manifold and replace ventilation pcv valve ? Hard job
Old Dec 1, 2024 | 01:52 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
CODES : P0507 P2279
can you find the English translation of these fault codes?
It does sound like it's the failed PCV that needs replacement. This is a standard failure of plastics under extreme heat.
Old Dec 2, 2024 | 06:24 AM
BlackML550's Avatar
2010 ML550 VIN WDC1641722A564750, 2010 B180
PO507 is Engine idle speed higher than expected?
P2279 Intake Air System Leak?
I'd start with looking for vaccum leakes given the P2279 and a smoke test would assit with that. There's a chance you have 2 seperate issues happening at the same time - Too much blow by caused by PCV not functioning and then a vaccum leak as well. Does the fuel trim data show anything that looks like a lean mixture? I'd try and reoving as many variables as possible first - clean the MAF sensor as a priority. Check your O2 sensors to sse what voltage they are throwing out and then maybe the EGR after that.
Noting the P0507 - have you noticed anything with the idle speed?
Replacing the centrifigal valve on the back of the head should be a maintenace item anyway, and is reasonably inexpensive. If you need to then replace anything further on that system, you'll want to change the centrifigal valve anyway.
Old Dec 2, 2024 | 02:46 PM
RobertR728's Avatar
2014 c300 w204.080 3.5 v6
Yes the squeal is from a failed centrifugal valve also called pcv system. It has a diaphragm that will tear and squeel terrible when warm. Fix that and three squeal will be gone
Old Dec 2, 2024 | 04:38 PM
TimC300's Avatar
If you replace the passenger cover and the drip pan, the drip pan is a reverse thread bolt. Be careful.
Old Dec 5, 2024 | 01:12 AM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
Crankcase ventilation valve failure is not uncommon on M276. You have the symptom.
