2014 C250 interior help
Old Dec 1, 2024 | 10:09 PM
Drayko's Avatar
MB 2014C250
I need help finding a couple things to fix the interior on eBay or somewhere links would be greatly appreciated! This is my first time fixing up a car so just looking for help and advice
1.both front seat covers are tore up I want to replace them if possible
2. passenger seat does not go back or forward it goes up and down a little metal wire was all jumbled up and I can’t find it anywhere
3. driver door handle doesn’t work from inside it’s just loose won’t open but outside does
4. wood trim panel on dash is cracked
5. button decals are all worn including the ones on steering wheel and stereo ones
6. the trunk cover that covers the spare is sunken in and won’t stay up
7. Center console double doors lids are broken
8. center console vent for rear is broken can’t chance direction of airflow side to side or up and down and the passenger front one
9 glove box lock broke off as I have to slam it up to close it
10. Rear passenger taillight has a big crack
11. in the engine area there’s a hose with fabric that brings air in it is torn
12. Stereo screen has dead pixels
13. Gear shifter leather is ripped up
14. The wheel whale on the driver side isn’t there I can see the tire from the engine bay and it’s not like that on the passenger side
Last issue that’s not inside is the alignment I took it to a shop and got it aligned and it still veers to the right any ideas? I really appreciate any help in advance I know it’s a lot but I want to fix this car up and have it looking nice again soon
Old Dec 2, 2024 | 03:59 AM
RobertR728's Avatar
2014 c300 w204.080 3.5 v6
AliExpress has allot of what you are looking for. Ii have bought many items for my car from there. Shipping time and communication is the only issue dealing with a China website.
Old Dec 2, 2024 | 01:35 PM
TimC300's Avatar
Your vin # would help. Even then it will be hard for someone to know which exact parts are installed in your specific W204. I have a 2010 so I would most likely have slightly different part variations.
As you said look on ebay for those things. When I look for things on eBay I type in "Mercedes W204 (whatever you are looking for)". Or AliExpress, I see they have the replacement steering wheel buttons for $20.
In the trunk my floor has sunken, its just a bad design in my opinion. I had some scrap wood I cut to fit and placed under it, its basically just resting on the spare tire but it keeps the floor from getting worse.
The drivers wheel well liner has two sections, a front and a rear section. Are both missing? You will probably also need the fasteners that hold it on. Mine has push pin type part# 1249900492 and also plastic nuts part# 2019900050 that hold them on.
I have the M272 which is different from yours. I think you have the M271 so the intake has one tube.
Tail light I would probably buy used instead of new aftermarket. Up to you.
For the seat wire i have no idea. Try and trace the wire and see if it has a label on it with a part#. Or post a photo of it.
When you had the alignment did you get any paperwork with it?
Old Dec 2, 2024 | 03:13 PM
Drayko's Avatar
MB 2014C250
Tim your the man! My vin is WDDGF4HB5EG250641 I will take pictures of everything when I get off work to upload should have done that yesterday my apologies I’ve found a lot of it on eBay I found the dash trim air intake hose rear taillight ac vent cover for back seat button stickers and front seat replacements so far I cannot find the rest
Old Dec 3, 2024 | 04:47 AM
RobertR728's Avatar
Instead of button stickers if you keep looking you will find actual button replacement. I would suggest those over the stickers if you can find them. There stickers are kinda tacky and don't look very well. Here's a example of the window buttons. The old ones pop off easy and you pop on the new buttons.
Power Window Switch Button Cover For Mercedes-Benz W204 C-Class W212 W242 W246 W166 W176 W204 E-Class E200 A2049055402
https://a.aliexpress.com/_mN0vQoB
Old Dec 3, 2024 | 02:26 PM
TimC300's Avatar
Looks like you have Beige 125A color interior.
I've seen stickers and the actual buttons and I would go with the actual button replacements.
Vents i think you found:
Center console doors probably have to buy a used complete assembly. Unless it is fixable depending why its broken.
Old Dec 4, 2024 | 09:46 AM
AAIIIC's Avatar
2014 C250 Luxury
Where are you located? Are there any "u-pull-it" type junkyards / auto salvage yards within a couple hours of you? A lot of the items on your list are the sort of thing you can easily grab at the junkyard without spending a ton of money.
