HeatAC fan failing intermittently
if the fan spins fine then start the car and put the heat on high, then see what the fan does.
May be a failing blower motor resistor.
I see they call it "Blower Regulator". Part 100. if it is faulty make sure to check the part# of the one installed in the car before replacing.
It sounds like the blower motor might be the issue. I replaced mine about two years ago on my 2013 C250. To remove it, I had to loosen the glove compartment and push it forward by about half an inch to allow enough room to rotate the motor out of the base clamps.
Did you have the fan set to full speed? Im not sure on Mercedes but i had a Jeep before that had a faulty resistor/regulator. The symptoms were the fan would only work on high, it would not work in any of the lower settings.
But since you say the fan wasnt moving initially but moved after you gave it a push leads me to think maybe the fan is faulty, or more specific the brushes in the fan. Im not sure how to test it though, wouldnt want you just replacing things without knowing exactly what is wrong.
