Car vibration at low rpms
It happens on this exact case mostly. If I am driving at lets say 2k rpm, I put off my foot from gas to slow down until 1k rpm and then when I accelerate again slowly it starts to vibrate. Surprisingly when I accelerate hard it does not vibrate.
The vibration is felt through the cabine and under the seat mostly. The moment it passes 1,4k rpm the vibration is gone. It is pretty hard to reproduce the issue even for service shops since you have to drive the car this specific way to cause it. I already checked the transmision and the guy said it was fine but he also said that it might need fluid change and a new trans mount. Another mechanic said that it might be the vacuum pipe or ignition coils. Do you have any idea what could it be? Even the slightest clue would be appreciated.
Thank you
Try to drive the car in manual mode and see if your shifting gets rid of the vibration. It's a easy first test
Might as well do the mount it's definitely roached at 180k.
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
