O2 sensor and exhaust leak
Old Feb 21, 2025 | 01:25 PM
MBislyf's Avatar
Mercedes C class
Hello everyone!
I was trying to fix a P0428 (catalyst sensor high input sensor 1) so i decided to change the upstream o2 sensor. After reset CEL is back on. I used a bit of soapy water to check for leaks (maybe o2 not fully seated?) and i see the pneumatic auctuator arm has a leak… could the problems be related? How do i fix the leak there and P0428? Ill attach a video i made so you guys can see it.
Any help would be appreciated! Thank you!
File Type: mov
Old Feb 22, 2025 | 12:07 AM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
I don’t recognize that engine from looking at the video. What is your model, year, and engine code? If that’s a diesel, I’ll have to let someone else handle it. P0428 can be triggered by fuel/air mixture problems or incomplete combustion.
Old Feb 22, 2025 | 12:37 PM
TimC300's Avatar
I know nothing about those engines. Not sure if the O2 sensor is the same as a temp sensor?
Heres a thread discussing the P0428 code. https://mbworld.org/forums/m-class-w...-positive.html
Old Feb 23, 2025 | 06:58 AM
MBislyf's Avatar
Mercedes C class
Hello guys! This is a w204, 2012 with the OM651, burns diesel. I just saw the thread… i have no clue what a temperature sensor is. Also in my case there is no P0438.(could be because its a bank 2 trouble code, and my car is a Inline4, thus only 1 bank). Any ideas about the exhaust leak in the video? Is there a way i could change that? Probably should be a gasket. Is that arm a simple pull and out or no? That is the stock turbo on the OM651 in the video.
