Fuel Pump Noise?
Today on my way to work, the reserve fuel level warning came on and at that exact same instant, there was a TERRIBLE screeching sound that was beyond loud from the same place. It did waver based on if I was accelerating or decelerating but only a little. It didn’t stop until I shut the car off and it stopped about 5 seconds after that. I’m leaning towards a speaker because to my knowledge the fuel pump would never make a noise like this, but the fact it came on at the exact same second as the warning is kinda strange. Let me know though, thank you all!
If you do think it’s the speaker as well, could anyone happen to know the part number for that speaker and I’ll just swap it out?
You can also turn the fuel pump on and off with a good scanner and listen for noise.
another thing you can do is look for water getting into the car or trunk in any way. If there's a leak it can cause crazy issues.
I don’t think there’s any water getting in, I keep a lot of things in the trunk that would definitely hold moisture if they got wet and I haven’t noticed any issues. I have a moisture check tool that inspectors use for checking moisture in walls and ceilings however and I could always use that in the trunk to make sure.
Thank you!
Thank you!
