Car shakes in neutral
Old Apr 12, 2025 | 05:12 PM
Limun's Avatar
Hi guys, this morning a check engine light appeared on my dash, the car shakes in neutral, what could the cause of this be? I have an appointment at the mechanic in 3 days.
Is it wise to drive like this?
Old Apr 12, 2025 | 05:15 PM
RobertR728's Avatar
2014 c300 w204.080 3.5 v6
No way to tell the cause without knowing the code and the cars info.
If it's shaking it could be a engine miss and that can foul out there catalyst converter which is expensive. So basically safe to drive butt might cost you more money in the long run.
Old Apr 12, 2025 | 05:41 PM
Limun's Avatar
Car info, C180(W204) 2011, 1.8l petrol 154hp
Yeah i figured, could it be caused by the spark plugs missfire?
Old Apr 12, 2025 | 06:17 PM
RobertR728's Avatar
Absolutely if there are old spark plugs it will misfire and set codes.
If you have no idea how old they are that's a good place to start.
Old Apr 12, 2025 | 06:26 PM
Limun's Avatar
Will check on that first, thank you!
Old Apr 12, 2025 | 09:07 PM
JettaRed's Avatar
Veteran: Army
Get yourself a proper Mercedes-specific scanner before you start throwing parts at the car.
Get a LAUNCH Creader Elite 2.0 BENZ. Check Amazon.
Old Apr 12, 2025 | 10:04 PM
TimC300's Avatar
Car shaking and the check engine light is on? I would not drive the car.
Save yourself some money by buying the Launch scanner mentioned above. No need to replace things that may not be the issue.
Old Apr 26, 2025 | 06:49 AM
Limun's Avatar
So after the diagnosis the problem was with the car's battery and the spark plug's. After changing both the car runs smoothly now.
Old Apr 26, 2025 | 08:26 AM
Faast's Avatar
'91 964 Turbo, '02 E55's & '14 E63s-w
Would this reset the CEL too?
Old Apr 26, 2025 | 05:20 PM
RobertR728's Avatar
Yes and much more.
