Mecedes w204 no ignition no fob
I have a issue with my c class w204 European model. I was driving it fine went out to the store and then when trying to go back home I noticed my key fob stopped working so I unlocked the car using my physical key and when trying to start the car it would not.
I am quite handy and started doing the rounds to try and figure out what's wrong and try to fix it myself.
Symptoms:
- key fob stopped working, I can't unlock it remotely (changed the batteries for good measure)
- when inserting the key into ignition and turning it on nothing happens
As everything was pointing out to a broken ESL I did the following
- battery Ok
- radio, lights OK
- Central locking ok using the buttons on the door
- checked fuses all seem OK
After looking at the many Mercedes forums I decided to remove the ESL and lo and behold to my surprise no ESL was there to be found. It turns out the car had this issue before and the ESL was replaced with a bypass.
Next thing I was thinking about was replacing the bypass and here is where you guys may be able to help me.
- how do I know the bypass is faulty ?
- can a broken ESL/BYPASS cause remote unlocking to stop working ?
No ESL at all
Bypass
Dash stays like this - no lights, nothing, fuel gauge doesn't move- even when key is at position 2
is at position 2
I don't think it's the ESL which is the electric steering lock one because you already have the emulator and because I think when the ESL is bad it will light up the dash and give you a error shown on the display I think.
Search ESL and EIS on the forum here thru advanced search and only search in the W204 section.
I could be wrong tho
Heres where I was looking for parts for the central locking, I dont see the steering lock listed: https://charm.li/Mercedes%20Benz/200...%20Components/
If you get a new fob it will require programming the same with the ESL and the EIS. I would lean more towards the EIS since you already have the ESL emulator.
What year is your W204, submodel?
I never dealt with this issue before. Looking thru the manuals it looks like there is a way to test each separate component.
My car is a 2010 model : (204) Berline 180 CDi 2.1 CDI 16V DPF BlueEFFICIENCY 120 cv
Here are some photos
When you open the door does the middle display turn on? Im guessing no. Makes me wonder if its an issue with the instrument cluster, maybe the fuse. It seems to have its own fuse in the front sam in the engine bay.
How did you check all the fuses, visually or with a multimeter? I would scan the car first for any fault codes. I would also check the fuses, focusing on the instrument Cluster fuse, also it looks like the Ignition Lock and the Electronic steering lock share the same fuse, im seeing two seperate fuses for both of them.
Heres a link to the fuse box diagrams: https://fuse-box.info/mercedes-benz/...uses-and-relay
- f19 ESL/EIS
- f27 ESL/EIS
- f28 Instrument Cluster
The key fob doesnt work to unlock/lock the doors, but when you press the unlock on the key fob does the fuel filler door unlock? Can you open the trunk using the key fob? Can you open the trunk using the button on the door?
When you insert the key and turn it to On can you hear the fuel pump kicking on under the rear seat? Do the windows and sunroof work?
What voltage are you getting for the battery? Have you tried hooking up a battery charger?
- f19 ESL/EIS
- f27 ESL/EIS
Battery is fine I and I replaced it with a newer one
Volage is 13,8 V
You appear to have the set of conditions to satisfy the Steering/Starting… Diagnostics that @TimC300 sent on 16 April. You have the ESL code A25408. It appears that by that logic, your ESL emulator has failed.
As for the lock/unlock failure, have you changed the batteries in your keys? That function requires fresh batteries.
I am, however, still a bit wary because the two problems seem to have occurred simultaneously. A new emulator may not be extremely expensive, but if it is changed and the problem persists, we are back to a hidden underlying issue.
The new emulator would have to be programmed. You could ask @BenzNinja I think he programs them but I'm not 100% sure he does.
But he is totally reliable and a good person to boot. You can message him on here to find out
Is that a definitive sign that it's broken ?
Also can I use the starter relay trick to jump start it ?
