JB+ Thumbs Down
Old May 31, 2025 | 09:30 AM
gav24v's Avatar
W204 C250 Sport (AMG Package with Pano Roof)
JB+ Thumbs Down
After changing plugs, coil packs and valve cover (OE), I fitted a JB+ tuner. It was a short experience for I got over boost related CEL, driving down my drive!
I cleared codes, set the JB+ to minimum, and still got CEL and limp home zero boost. I'm sending it back.
Has anyone got experience with Race Chip?
@antboii How has the Racechip experience been for you?
Old May 31, 2025 | 10:39 PM
JettaRed's Avatar
Veteran: Army
How are we supposed to know what car you have and what you are talking about?
Old Jun 1, 2025 | 02:49 AM
smgak's Avatar
C230K
It’s pretty obvious if you search Google for “JB+ Tuner W204”, especially when the OP mentions “boost”.
Old Jun 1, 2025 | 07:46 AM
JettaRed's Avatar
Veteran: Army
OK, what car did he install this tuning box on? What year? What engine?
Old Jun 1, 2025 | 07:59 AM
smgak's Avatar
C230K
C250 with the M271. Why would the year matter?
Old Jun 1, 2025 | 08:05 AM
JettaRed's Avatar
Veteran: Army
How do you know that?
All I know is what the OP posted. If someone is going to ask for help or make a comment, it is courteous essential to identify the vehicle that has the problem. Otherwise, we are left guessing and many folks won't bother.
Old Jun 1, 2025 | 08:07 AM
smgak's Avatar
C230K
Have you tried making adjustments according to the installation guide?
“Adjustment:
The tune ships preset for most DME versions, which is approximately 50% on the internal dial. But due to car to car variance adjustment may be necessary. If the dial is set too high the vehicle will experience "reduced power" conditions where the gas pedal feels dead until you restart the car, and an over-boost code may be triggered. If you experience either of these conditions then lower the dial by 10% until they subside. To do this remove the two screws exposing the JB+ circuit board, and use a small screwdriver to turn the dial towards the "MIN" setting. Note even at the MIN setting the tuner is still adding horsepower. For OEM performance levels remove the tuner completely.“
https://cdn.shopify.com/s/files/1/08...12755747617271
Old Jun 1, 2025 | 08:20 AM
smgak's Avatar
C230K
And double check your connections to be sure they’re making good contact!
Old Jun 1, 2025 | 10:15 AM
gav24v's Avatar
“Adjustment:
Yep. I dialed the settings back to minimum. My drive is about 300 ft long and I was getting a CEL before reaching the mailbox. That would be 15 mph max.
Old Jun 1, 2025 | 10:18 AM
gav24v's Avatar
Thanks. Yes I did this. The connector quality is good on the JB+ even though the box itself looks like something from Radio Shack.
Old Jun 1, 2025 | 10:43 AM
JettaRed's Avatar
Veteran: Army
@gav24v do you have a scanner that lets you read realtime boost? Or can you hook up a mechanical boost gauge (temporarily) to see actual boost? I don't know what normal boost is for your engine, but there is chance your JB+ device is defective. Normally boost only occurs under load. Backing out of your drive should not load the engine unless it was a steep uphill driveway. Can you view your wastegate actuator? If so, have someone rev the engine and see if it moves at all.
Old Jun 1, 2025 | 05:58 PM
gav24v's Avatar
Thanks. The performance is as expected without the JB+ with no CEL or codes. After talking to BMS they have stated that the unit is faulty.
I was doing about 15mph on the drive and in 2nd gear. On the min setting the CEL came on when on the subdivision at about 20mph.
Old Jun 1, 2025 | 08:40 PM
JettaRed's Avatar
Veteran: Army
Let's hope that the CEL was a false positive due to the JB+ device messing with the electronic signals. If you were truly overboosting, you would feel it. I had a 2000 Audi A4 wtih the 1.8T and had the vacuum line that controlled the wastegate fail and ended up blowing the engine under slight acceleration. Fortunately, Mercedes has the wastegate to fail open.
Old Jun 1, 2025 | 09:37 PM
gav24v's Avatar
Definitely due to JB+ . Zero issues before fitting it, perfectly ok after removing it and clearing codes. Thanks for the follow up.
