Timing chain?
Old Jul 16, 2025 | 06:50 PM
Tuncer17's Avatar
2012 C180
Timing chain?
Hi!
Bought a 2012 C180 with 129.000 km 3 months ago. Now done 136.000.
Ever since I bought it I have noticed a rattle on startups. It’s worse when the engine is warm, quite a bit worse. On cold starts it’s still sometimes noticeable but definitely less common. I’ve attached a link at the bottom of the text to a video of me starting the engine on a hot summer day after driving for 2 hours. I checked for codes and the car shows none what so ever.
So the question is, what exactly is the problem? Timing chain? Camshaft adjusters? Both? How many hours of labor are we talking for a local mechanic with little experience in changing timing chains.
When doing the chain, is it enough to change chain alone or will that be just a waste of time?
To be honest, Im thinking of changing to a w212 in 6-9 months or so. Anyone reckon if the engine will hold until then or is this urgent?
Any help would be appreciated greatly!
Link
https://youtube.com/shorts/rCbMM3ngLlc?si=JkxMpGjcVcNCOVT-
Old Jul 17, 2025 | 10:42 AM
gamma300C's Avatar
2009 MB C300 Sport 4matic
Cold start vs hot rattle would point more towards the tensioner failing over a slack chain per us "shade tree' mechanic's take. A change out would just as well include the chain albeit easier/cheaper to just change tensioner plus no need for chain breaker/riveter tool. If you are going to trade her in a failing tensioner might make it for quite a while if you don't push the RPM's, drive like a "senior" ! You could also in the meantime try a little BMW 5W-60 syn. oil drain/refill and see if the warm rattling gets better..the stuff is a bit hard to find and pricey. Or some Rotella 10W-50 might do the trick.
In summary, timing chain noise more noticeable at startup, idle classically. If you get a P0016 or P0017 code in the future that would suggest the chain has slipped a tooth.
Old Jul 17, 2025 | 10:47 AM
Tuncer17's Avatar
2012 C180
So an oil change with some thicker oil for now then. Thanks for the advice!
Old Jul 17, 2025 | 10:59 AM
gamma300C's Avatar
Let us know how it works out....
Old Jul 17, 2025 | 03:04 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
While at 136,000 km you could have camshaft adjuster failure, the noise in you video is no where near as bad as what that failure produces. Failed adjusters also throw codes, so lacking them is a good sign. A “stretched” chain or a bad tensioner seems like the most likely culprit. It is not uncommon for M271 engines to need chain replacements around 160,000 km. If the noise does not get better with higher viscosity oils, replacing the chain and tensioner may be in your future. A chain jumping a cog on M271 could be fatal to the engine because of valve/piston interference.
Old Jul 17, 2025 | 03:07 PM
Tuncer17's Avatar
2012 C180
Hi!
Thanks for the advice, good to know its not the adjusters. They seem pretty expensive. Will change the oil after holiday. I will make sure to get back to you guys about the outcome!
