Rough idle after replacing thermostat housing
- Starts fine but rough idle (bouncing around 800 to 900 RPM)
- P0108 code which I never had before - cleared the codes and it came back.
- Drives great
- Coolant level good and bled the system (with the vehicle front raised) and no air in the system
- Double checked all connections are plugged in correctly
- I replaced the front large intake pipe because rubber had hardened and couldn't get it on the turbo inlet
- Used the old MAF sensor from the old pipe - no difference
- All vacuum hoses tight
- Tried using brake cleaner to find a leak (nothing)
- While car is running removed the plug on the MAF sensor (the one on the large intake tube) and no change in idle
- I tried testing the wires on the MAF sensor (used a good ground) and saw no volts on any of the pins
- Expect to see at least 5V on one of the PINS with the key in the ON position and while the vehicle is running
- I remove the ground wire (the brown wire on the harness), cleaned and reinstalled
- Checked the fuses and all are good
Does anyone have any other thoughts on this?
Richard
Does that make sense?
Richard
For benefit of others here's the process I did for the ECU to relearn...
I disconnected the negative from the battery for 30 mins, ensured all vacuum lines/connectors were tight, reconnected the battery, turned the vehicle to the ON position, waited about a minute, started the vehicle, waited for a minute (idle was rough), turned on the AC, waited for a minute, turned off the AC, and went for a regular (not hard) drive for about 20 mins. All was good and when I got back idle is great and no issues or stalling when going slow and turning the wheel (which is when it stalled before).
Richard
I let the car cool down for a few hours and when I started it again I had a rough idle. No stalling or anything. Maybe I just need to drive it more to adjust since it's fine when it's warmed up. Other than that at this point I'm thinking...
- Small vacuum leak when the car is cold - probably do a smoke test
- MAP sensor gone bad - seems coincidental but I still get the P0108 code
- Bad wiring - maybe I broke a wire somewhere but all was fine before I didn't yank on any wires.
