Power Steering Malfunction, EBV, ABS, ESP Inoperative
When I exceed the speed of 23 km/h (approx. 14 mph), several warning lights come on: EBV, ESP, and ABS. Additionally, the power steering becomes extremely heavy, making it difficult to maneuver the car. There is also an error code stating that the tire pressure monitor is inoperative. If I try to use the Cruise Control, another error appears.
This issue first occurred earlier this year; I continued using the car and one day the problem simply vanished. However, a few days ago it returned. I tried the 'lock-to-lock' steering wheel reset (turning it while in reverse), but it didn't work. My first thought was the battery, so I replaced it with a brand new one, but the problem persists.
What caught my attention is the voltage: when I start the car, the battery peaks at a bit over 14V, but then it starts to drop and stabilizes at 12.6V—even with the lights and air conditioning on (this happens with both the old and the new battery).
Could this be a faulty alternator? It is worth noting that when I start the car, no errors appear; the alerts only pop up once I pass the 23 km/h mark.
A dedicated Mercedes scanner would probably show trouble codes to help pinpoint the failure.
