- Mercedes Benz C-Class: Tire Pressure Monitoring System
Important information to help you understand your Mercedes-Benz
Browse all: Tire Repair and Maintenance
Tire pressures on the C Class
Note:
(yes, I realize that I am from New England and I am talking about going out and purposefully deflating things)
On both sets of tires, I have gone as low as 34 psi all around and as high as 43 psi on the rear tires. On the Contis, I have noticed minimal change in ride quality regardless of tire pressure. That was surprising. With the snow tires, which are not RFT's, there was slight improvement in ride with lower pressures. Handling did not seem dramatically different either way.
I spent two weeks running the snows at 34 psi all around, then went to 38 psi all around. The car actually felt better at 38, so that's where I'll keep them. These are all cold tire pressures.
Fuel economy seemed a bit better with the higher pressure, but that's not a surprise.
The only conclusion I can reach is that tire pressure is not critical with this car. With my Porsche, every couple of pounds changes the handling and ride characteristics ... with this car the changes are very subtle.
I'm in the car alone most of the time, and <100mph. Based on the photos, I'd probably run 32/35 (based on the cars sometime feeling the back disconnected if same pressure) and then watch for wear closely as Glyn discussed above and adjust accordingly. It won't be night and day for you for smoothness, but it is a start. Not sure if could work a swap to standard 17" wheels, that would probably be only other cost effective measure w/o getting into swapping to the Luxury package springs/shocks. BTW, I can understand, here many roads are flat concrete with expansion joints which have been patched with asphalt. Sportier suspensions are a punishment on them, and not really any curvy roads in the state to utilize the stiffer handling.
You may need to reset the TPMS in the settings menu. Please let us know what you go with and if some positive results.
When delivered in early Feb., my C300 had tire pressures from 37 to 40 lbs. The on-board TPMS system agreed exactly with my dial pressure gauge. The ride was much stiffer than my previous 2007 C2804MATIC Luxury. That car had 16" 205/55 Michelin Pilot Exalto A/S tires. Perhaps because they were at least 80% worn, they rode very well.
Yet, contrary to all other commenters, I believe my Pirellis now ride at least as well as the Michelins did! I say this because I am comparing only those aspects of ride for which I consider tires directly responsible. I am referring to the effect of broken surfaces, with patches, tar strips, and so on. On these surfaces, the Pirellis absorb the roughness quietly and smoothly.
Where my C300 comes up short is on wavy surfaces, frost heaves, and other undulations in the pavement, even where the pavement is not broken. These set the whole car in motion, giving a jiggly ride. The car does not bounce; it really follows the road surface too well. The effect is more sporty than the ride of the C280, but less comfortable. This I consider the effect of the suspension, not the tires.
After reflecting that I was unlikely to do any cruising at 100+ mph(!), I reduced the tire pressures in steps to 32 psi front and 34 psi rear. That is what was recommended for my C280, and that is what I used. Yes, the recommended pressure for the rear tires was slightly higher than for the front. However, shortly before I traded it in, the manager of the independent shop where I had my C280 serviced told me that the shoulders of my tires were wearing excessively. That meant under-inflation; I certainly don't challenge curves. I will either keep an eye on the wear patterns or, more likely, run 34 psi all around.
Using 32/34 as tire pressure has made a slight improvement. The car now jumps around a little less. I am not an engineer, but I think this is because the softer tires transfer less energy to the suspension. On all of my previous cars, slight over-inflation improved the ride. I reasoned that the tires were transferring more energy to the suspension. The suspension dissipates energy as heat from the shock absorbers. The tires dissipate less energy; they merely release it elsewhere, including back to the road. The timing of this release matters a lot, cushioning or reinforcing impacts and exciting or dampening resonances.
I just upped my pressure from 33 (started in summer at 36, but it's colder now) to 37 front/38 rear. Haven't driven much yet on it, but it seems a bit more harsh (base steel suspension on 18 in runflats). Since I don't EVER get above 100 mph am I running pressures too high?
Also, has anyone noticed whether gas mileage improves with higher pressures?
I can't imagine that MB would have the sticker or manual wrong.
