Ground to fender height
#76
2015MB C300 4matic, Lexus NX
Not sure the look up VIN URL is accurate. I have a C300 4 matic with the 18" multi spoke - NO sport package but when I run my VIN it shows I have 486 sports suspension. I wish I had that but there's a 4 finger fender to wheel gap!
#77
I'm in LA for a meeting for a couple of days and I've seen several C300s and all of them have had a much smaller wheel gap than my car, and not a single one of them were Sport pkg cars.
#78
2018 GLC300 4Matic
I noticed this the other day at my Gym. A brand new W205 non sport with the twin 5 Spoke wheel looks to have been fitted with the Sport suspension because the ride height and wheel gap looked perfect unlike the earlier builds. I guess someone at MB is making up for all the Sport PKG cars that left with Comfort Suspensions.
#79
I dropped my car off at the dealer on May 8th to have them replace the bleeding MB-Tex and confirm the incorrect suspension. I just got a call telling me I could pick it up. I asked about the suspension and was told they don't have an answer from Mercedes...so it basically sat there for almost two weeks to have the front seats covers replaced.
#81
OEM PARTS SWAP from 485 to 486/677
maybe I'm wrong, but according to my calculations by changing 18" 245/40 with 19" 255/35 (rear) the distance btw. tire and fender should decrease by 4 mm ... of course, don't know the visual impact...
any photo of AMG exterior + standard suspension (485) + 19" wheels is appreciated + C300 or C250 bluetec 4 matic ...
thank you,
amo
thank you,
amo
swapped my 485 suspension on w205 exclusive to a 486/677 with avantgarde shocks and struts. Stock avantgarde suspension basically. Got the lowest 486/677 springs possible ( vary when considering weight).
I got the parts numbers if anybody is interested.
€1,600.00 is how much the swap parts cost.
#83
Spring and dampers are typicall specced at factory based on:
Spec ie sports or comfort or other
Vehicle build model (mass related, engine, trans, fwd vs rwd, and build spec again mass related)
Market specific requirement (eg additional ride height for rough road pack)
The matrix for vehicle options vs suspension spec is large..
The number of permatations of damper and spring are often in the hundreds. The Assembly line build (ie combines) the specced damper and spring in accordance to the overall spec of the car ie a combination of the factors above... parts are sequenced to the suspensin assy line in the same sequence as the main line, the suspensions sus assy's are built to the manifest and sent to the main line and fitted to the car.. thats a typical manuf scenario.
IT IS POSSIBLE FOR:
The spec matrix and hence build manifest to have an error
For the suspension assy line to mis sequence parts with in a buil dset (ie one vehicles set)
For the suspension assy line delievry sequence to fall out of synch with the main line.. ie cars receieve the wrong suspsnsion packages en masse..
Usually these things are found at aay point inspection, pre set delivery inspection, main line pre fit inspection, end of trim line inspection, ne dof main line inspection at function.. the vheicle would be offlined and repaired..
BUT it can happen that despite all these measures a **** up gets external.. so its alays worth checking the vehicle build spec and the colour coding (paint stripes) on the springs to the correct factory spec.. if you are concerned that they may be incorrect.
Hope there was something useful within that..
#84
