Is it possible to run iGo Primo on 2015 C300?
It's mentioned that it has "SD-Card Navigation Pre-wiring".
Is it possible to run iGo Primo on a SD-card?
Normally, I'd abandon the in-dash navigation. But this 2015 model has this LCD sticking out. It looks awkward to have another one. Does anyone find a good way to mount a standalone GPS unit right above it?
I am in an above ground parking lot but you get the general idea of the 3D buildings
I am sure you can find a way to do this, the real question is why?
It will definitely make both the Command and attached GPS setup look like an after thought.
All portable GPS are touch screen, so you will be reaching up to program location, etc, unless you find an easy dismount solution.
The Mercedes GPS is considered one of the industry best.
There are several settings that can enhance your Navigation screen.
Showing upcoming side streets, birds eye view, 3D in built up areas, etc.
Here is an example of what the 3D screen looks like;
http://www.navitechus.com/#!monitor8/c20v5
This is GPS box for igo primo with SD card
http://www.navitechus.com/#!mst-1000/cvpl
I have been trying to get more info on it (Garmin Map Pilot) since its not available here in Canada and my dealer has no clue. Even started a thread for it but only crickets so far!
