Lowering with Airmatic
#51
This is not the case, to which i have argued my point. I do not need personal experience with a links-lowered C class airmatic to know I am right on this one, you just need common sense and basic knowledge. I mean just look at your car. it looks ridiculous..
The interweb if stacked full of people reporting about......
This forum has mostly too good of people for some saying how others ride 'looks ridiculous'. Even if it's not your particular taste, this isn't a caddy middle school chat room.
I'm also with floridadriver 's comment. Unless you have personal experience on this car, you don't really have anything to argue about here either. I'd at least try someone else's success story before I disagreed so adamantly.
#52
Lowering a C class
I would be interested in doing the opposite - raising my 2005 E320 4Matic (W211) so it wouldn't bottom out on Vermont mud season dirt roads. I don't have the Airmatic suspension.
Any ideas would be much appreciated!
#53
There wil always be some living in denial. Those who claim you can slam your car, or stick on massive wheels with rubber bands for tires, and still retain factory ride quality.
![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
#54
Eilers, considering your constant serach for dirt while looking through member logs you should also have noticed that my comment regarding Comfort was made before I fitted 20.s.
But I guess that is your big problem, you are so adamant in trying to prove others wrong that you disregard anything but your own percieved truths.
#55
2015 C300 RWD
Right.. and you need to buy Herbalife before you can say it's a ponzi scheme..fine logic there..
There wil always be some living in denial. Those who claim you can slam your car, or stick on massive wheels with rubber bands for tires, and still retain factory ride quality.![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
![Sadwavey](https://mbworld.org/forums/images/smilies/sadwavey.gif)
#56
It seems you missed the context of the thread. VicViper isn't 'selling' anything....only amiably pointing out his work with his car's airmatic and his personal perspectives first hand when he was asked. And you're bringing....Herbalife...and argumentatively what your inexperience on lowering this car tells you. YOU don't like it, it's clear, move along.
I like the look, and really enjoy reading stuff like these mods people are trying out. Then again, I'm a junior 'Benz junkie so to speak.
#59
We have a lot of speedbumps in my area as well, none of them has made me rub or hit anything yet.
Also if I find a bump higher than normal all I have to do is select the Comfort agility setting or maybe even"raised" button.
#60
![crazy](https://mbworld.org/forums/images/smilies/crazy.gif)
Apparently you do not understand that you are dealing with, or you only realised it too late, after I spoke on the subject.
How can a technician not know that the car has conventional hydraulic piston/valve operated shocks, and not understand what happens when you drop the car by as much as you have?
No amount of reprogramming is going to absolve the fact that the shocks on your car will have to do the same work as before, but in less time and with less piston movement available during compression.
If you could reprogramme both compression and rebound ratio on the shocks, (which i am 90% sure is not possible on this car) then you can tune it to avoid bottoming out and not be unsafe and seriously uncomfortable to drive with the rebound all out of wack.
But (unless you physically expand the volume of the shock housing) you can never never never never compensate for the shorter piston stroke during compression. This translates directly into a firmer ride. The more you lower it, the firmer the ride gets.
From what i read, you just reprogrammed the airsprings to accomodate the lowering links, and then assumed the sensor operated adaptive function of the shocks allows them to work inside the range. That is quite the assumption!
Either way, in both scenarious, you will get a firmer ride, so your claim is ridiculous purely from the technical side of things.
That which i just outlined, - combined with you having a side business selling parts to people here and there, leads me to assume that you work at the MB dealershp as a Parts Clerk and not as a Technician. Am i wrong there?
If you have anything to add on the technical side of this discussion, then I am all ears. The personal attacks.. them we don't need.
#61
Dont even start with the personal attacks, look over your own posts first will you.
Also I cannot see why you keep ranting about this?, I have never said that lowering an Airmatic vehicle is optimal or benefitial for the system in any way, I am very well aware of the technical aspects of the system, no need for you to explain it.
Also you are mistakenly claiming that I can perform "wonders" with the diagnosis computer?
As I have explained several times in this and other threads all I do with the diagnosis tool is fine adjust height as well as setting the wishbone angle parameters, this has nothing to do with bound, rebound and what not.
The members on this board are interested in personal experiences, there is no need to go into technical details, and here I have provided my opinion, everyone but you takes it for what it is, and you havnt even driven a lowered airmatic vehicle, my guess is that you havnt driven an airmatic vehicle at all.
Read my words again, I have never written anything about my lowered vehicle being the SAME as a non lowered, that is a pretty big difference.
Talking about avoiding the subject, you havnt answered any of my questions, for what reason do you think would I lie about my experiences?
I am not selling the links, I am not making any royalties on anything regarding this, and why are you seemingly the ONLY one here claiming that I am lying?
It is so obvious that you hold a personal grudge agains me and that you do not tolerate being proven wrong and you must spend tonnes of post making an apparent fool out of yourself.
Regarding my position at our company, have you ever considered that one person can have several different work tasks and titles? We are a small family business, I am also in charge of IT, maybe worth mentioning considering that you seem so curious?
And does it matter?, I dont care what you do for a living, but it is pretty obvious that it has nothing to do with cars
#62
In case you missed it, i own a S205 Airmatic.
#63
Oh you are in motorsports, but of course you cannot tell any details? ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
I have nothing to hide and I never have, please feel free to browse all my previous posts (oh sorry forgot youve already done that
) also I am not changing my initial statement if that is what "redacting" mean, still got to give it to you, your English is better than mine.
You judge me for talking around the subject and then you make a post like this?, you know what double standards are right?
Bottom line, you are nothing but a simple troll, and yes I have failed, because I couldnt resist feeding that troll.
#64
#65
Couldn't agree more and thanks for the support, I feel it is a shame that threads that could be informative for others gets "infected" with these nonsense discussions, and as I mentioned before I take part of the blame, I obviously should have ignored him long ago.
#68
2 Vic Viper i have ordered lowering links from here http://www.ebay.de/itm/Tieferlegung-...item338fe56005
I am going to install it by myself, I want to lower the car aproximately 20-30mm maximum. I am prepared for alignment, but how to tell dealer to do the job in Star software?
#69
Just remember to have the car in Comfort (default height) when fitting and adjusting the links.
The tech should then through Xentry enter the airmatic control unit and perform a level calibration, it is very self explanatory and they should be able to work that out with ease.
#70
#71
There is actually no need to do a level calibration if you are satisfied with the height after fitting the links.
The hardest part is to remove the stock links without damaging the sensor or the upper brackets as they only sit in a very thin spring assembly.
Remove the spring assembly and the lower nut on the level sensor and then remove the links while out of the car.
#73
@vic viper
Thank you for sharing your experience.
It was great to read and learn.
After having after market air suspension on all of my previous car this will be my first factory fitted air suspension. Hopefully will be delivered at the end of September.
As I do after market air suspension solutions for living(second job
)let me tell you what I know about comfort and lowering.
Air bags on air suspension cars behave like progressive springs.
More you inflate firmer the ride becomes. It is simple logic.
Same principle as your tires.
So at mid level you get optimum comfort.
But when you lower it than it becomes more comfortable until you bottom out(or if you are bottoming out on bumps etc)
With adaptive suspension it should be joy to drive with lowering links since you get firmer shocks. That will make an excellent duo since damping adjustment make it difficult to bottom out.
