Anybody know what this campaign is?
Old Jan 11, 2015 | 12:07 PM
StanNH's Avatar
2015 C300 Sport: Palladium, Premium, Multimedia, Leather, BLIS
This is listed as an open campaign for my C300, and I have no idea what it is.
Can anyone here decipher this?
205 EVAP SYSTEM, OPEN 2014-12-18, Campaign Number C1A141201
Old Jan 11, 2015 | 12:14 PM
Leslielp's Avatar
2020 CLA 250 4Matic Black
Is this an error code that popped up?
Its looks like its referring to the Evaporator System which is AC (I think)
Time for one of those code diagnostic boxes.
If its not an error code then its some MB internal service code would be my guess.
Old Jan 11, 2015 | 12:30 PM
StanNH's Avatar
No, it's just listed for my car under my MBRACE account. No problems at all. I believe the EVAP is part of the emissions control system.
Old Jan 11, 2015 | 06:41 PM
Glyn M Ruck's Avatar
Super Moderator
It's the EECS. Evapourative Emissions Control System. Filler, tank breathers, charcoal canister & purge valve into the inlet system.
They must have a glitch. It should throw a code.
Typical codes.
P0440 Evaporative Emission Control System Malfunction
P0441 Evaporative Emission Control System Incorrect Purge
Flow
P0442 Evaporative Emission Control System Leak Detected
(small leak)
P0443 Evaporative Emission Control System Purge Control
Valve Circuit Malfunction
P0444 Evaporative Emission Control System Purge Control
Valve Circuit Open
P0445 Evaporative Emission Control System Purge Control
Valve Circuit Shorted
P0446 Evaporative Emission Control System Vent Control
Circuit Malfunction
P0447 Evaporative Emission Control System Vent Control
Circuit Open
P0448 Evaporative Emission Control System Vent Control
Circuit Shorted
P0449 Evaporative Emission Control System Vent Valve/
Solenoid Circuit Malfunction
P0450 Evaporative Emission Control System Pressure Sensor
Malfunction
P0451 Evaporative Emission Control System Pressure Sensor
Range/Performance
P0452 Evaporative Emission Control System Pressure Sensor
Low Input
P0453 Evaporative Emission Control System Pressure Sensor
High Input
P0454 Evaporative Emission Control System Pressure Sensor
Intermittent
P0455 Evaporative Emission Control System Leak Detected
(gross leak)
P0456 Evaporative Emission Control System Leak Detected
(very small leak)
P0457 Evaporative Emission Control System Leak Detected
(fuel cap loose/off)
Old Jan 11, 2015 | 06:47 PM
StanNH's Avatar
Thanks, Glynn. That will get done when the car goes in for the bleeding seats fix.
Old Jan 11, 2015 | 06:54 PM
Super Moderator
Stan ~ if there is an actual leak they must smoke test the system & locate it. It might be something stupid like they did not tighten a clamp properly. On 2005 W203's the filler pipe used to crack in a very low proportion of cars. Will be interesting to know what the issue is. Please ask them.
Old Jan 12, 2015 | 04:44 PM
jkyriakou's Avatar
C250 CDI coupe, Obsidian Black Vision Pack, Drive Assist Plus pack, Comfort Pack, Rev Camera
Doesn't a campaign signify either a recall or corrective action by the manufacturer on a part that may be faulty?
Old Jan 12, 2015 | 05:08 PM
Rocman8's Avatar
E55
This Customer One Action has been initiated, as an audit, to verify the functionality of the evaporative system on affected vehicles. An authorized dealer will perform an evaporative system check using Xentry and open a PTSS case for further instructions ONLY if an evap leak is detected. Vehicles in dealer inventory must be checked prior to vehicle delivery. To perform the test the tank fuel level must be between 30% and 90% full.
Old Jan 12, 2015 | 05:29 PM
StanNH's Avatar
Thanks!
Old Jan 12, 2015 | 05:40 PM
Super Moderator
Good stuff!
