Old Jun 24, 2015, 11:49 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Specifications and General Maintenance
Print Wikipost
Agility Select
Old Jan 19, 2015 | 01:10 AM
nigel8210's Avatar
C200
Agility Select
When I first got my ride, I can feel the steering weight difference between
Eco/COmfort against Sport/Sport Plus
but now it all feels the same, anyone has the same issue?
There is no onboard error message but I am pretty sure there is no difference now
my wheel pressure is 250Kpa as recommended
Any advice?
Old Jan 19, 2015 | 08:40 AM
StanNH's Avatar
2015 C300 Sport: Palladium, Premium, Multimedia, Leather, BLIS
Any advice?
I've never felt any difference in the steering between Eco and Comfort, and only a slight change with Sport. Sport+ does add weight to the steering, but that's not a selection offered through the Individual setting for some reason. The changes, even in Sport+, are certainly not dramatic.
Old Jan 20, 2015 | 08:52 PM
emilryba's Avatar
C3004matic, BMW 328d xdrive C w206 AMG line
Only if you have Airmatic changes using Agility Select are experienced. In another case, there is little difference between Eco, Comfort and Sport and Sport +
Old Jan 20, 2015 | 09:29 PM
StanNH's Avatar
That has nothing to do with the steering, which is what the OP was asking about. Agility affects the steering, the shift points, and the throttle response without Airmatic. With Airmatic, it also alters the suspension settings.
Old Jan 20, 2015 | 09:43 PM
emilryba's Avatar
yes you are right - your explanation is technically true. OP mentions, however, about the impression and feeling - and then Airmatic and Agility Select Affects the steering, the shift points, the throttle response and the suspension settings and it is what OP expected -overall changes in the characteristics of the car with one switch
Old Jan 20, 2015 | 11:29 PM
nigel8210's Avatar
C200
i do not have Air Matic so Agility Select for me affects only Steering Weight/ Throttle reponse or Gear Shift Points
When I first collected the car 4mths ago, I can truly feel the weight difference of the steering between
1. Eco/Comfort
against
2. Sport/Sport Plus
But now not anymore, very strange, there is no onboard error
I tried to play with I mode (individual mode) for the steering toggle and confirmed no difference when I switch both comfort and sports steering
There was an event last week though, I had an SRS warning
which the dealer found nothing and they just cleared the fault through an software diagnose
I was assured it was not the notorious "clock spring" faulty in the steering column as the vehicle is new, but now I am not too sure anyway.........
seems like something is indeed not quite right
