No traction on icy roads
2014 220 AMG
I have been unable to use my car for the last two days due to my living at the top of a hill and the approach roads which are covered in a sheet of ice. This is the first rear wheel drive car I've owned and I'm dismayed at how poorly it copes with the conditions.
I have ordered a pair of snow socks hoping this will give me enough grip. I have also been advised to load the boot/trunk,with bags of sand to weigh down the rear which should help. Is there anything else I should try?
A set of winter tyres is required I have them fitted to my C200 better than 4x4 on summer tyres during winter.
2014 220 AMG
The cost of winter tyres are prohibitive considering we rarely have the conditions to justify that. This snow socks seem the most cost effective solution,provided they live up to the hype. Watch this space.
The W205 is rear wheel drive,UK,spec.
Any wide contact patch tire on a RWD car is going to be unsafe in snow/ice and unpredictable in COLD without winter tires. Summer tires turn to rocks at 40 deg F and all seasons harden as well, as the temps drop significantly decreasing the handling capabilities. This is very common for higher end cars like Mercs, BMWs and Audi's because the tires they choose to fit on the cars significantly improve the ride/handling when the temps are on your side.
Now I know that this sort of sucks, but it is a fact of life, you really need winter tires, and not just for snow. Don't forget, you won't be putting the miles on your all season tires during the winter so they will last longer, significantly longer if you are not spinning them all the time in the winter. It just ties up more money in tires, but the cost is spread out over a longer period of time. Winter tires are designed to be run in the winter and they will save your 3season tires for when they are at their best. I have no direct experience, but I am pretty confident that it gets pretty cold in Glasgow. You will really thank yourself once you experience how your car drives on a good set of winters.
2013 650i Coupe, 2010 IS250 AWD, 1999 S500
These threads are hilarious. No car will do anything on a hill covered in a sheet of ice. Winter tires are a must if you're going to have a prayer in such conditions.
M
M
1 Post
W205 C400 AMG (Sedan)
Mind you it is not all about snowy or icy road conditions. Summer tyre has a different rubber compound, which hardens below aforementioned temp effectively stretching your braking distance.
BMW e89 Z4 sDrive 35i & MB S205 C200 AMG Premium Plus
In the BMW I've never considered winter tyres because they're insanely expensive on 19" wheels. However 18" wheel winter tyres are way cheaper and I'd seriously consider these next year, once I've actually received the Merc.
C200 AMG Line Premium Plus
Hi alenko
If its of any help, I'm from the same part of the world as you. I work in East Kilbride, where it snows in July![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
Prior to the Mercedes, the last rear wheel drive car I owned was a Lexus IS250. I didnt invest in winter tyres and to cut a long story short, the car got stuck in the office car park for over a week due to snow and ice.
I've learned my lesson and I've invested in some smaller, 17 inch wheels for my C200 AMG Line, with Blizzack winter tyres. While it has been a mild winter so far, the winter tyres also perform well in wet weather, which we have had plenty of.
I paid £1700 for wheels and tyres. My "normal" 18 inch wheels are being stored by the dealer and will be refitted, free of charge, when I request it in Spring.
It may seem expensive but over the 3 years I will keep the car, it is worth it for the peace of mind value alone.
Performance in the recent snow and ice has been faultless and at no time have I felt that the car was anything other than under complete control.
I honestly think its a worthwhile investment.
2014 220 AMG
Thanks to all who replied. The consensus opinion is that I should bite the bullet and invest in winter tyres. I agree,as it is a nonsense for me to have a vehicle locked away in my garage while I wait for a thaw to arrive.
