Turning it off...
Old Jan 25, 2015 | 02:58 AM
bensales's Avatar
Turning it off...
Maybe I'm just being stupid or this is how it works. Car has keyless entry & keyless go. In my Jaguar, you turned the car on with one press of the button, or started the engine with a long press. In the C, that at least appears to be the same, except with short presses you can do one for 'a little bit on', two for 'a bit more on', and a long press for engine start.
It's turning it off that puzzles me, mainly because it doesn't seem to power down until I open the door. In the Jag, one press of the button turned the car off. Everything. Just like turning off and taking the key out in ye olden days. In the C, it still seems to be on, along with the stereo blaring away which is the most annoying.
Am I just doing it wrong? Should there be several presses to stop and turn everything off? Or is this just how it works? I'm got the MB Guides app on the iPad and ploughed through the manual but it's not very enlightening.
Old Jan 25, 2015 | 03:56 AM
vic viper's Avatar
S213
I think you need to identify what is what here first, in a regular key setup, the car has ignition 1, ignition 2 and start position with the key.
A keyless go system is pretty much the same, one press (without brake) turns on ignition position 1, another press turns the car in ignition position 2, and another turns ignition off.
When brake pedal is pressed a short press on the start button starts the car, no need for long press.
Turning the car off by a short press leaves the car in ignition position on, and as soon as you open the drivers side door the system turns off completely.
I wouldnt want the car to completely black out (lights and stereo) once you just turn off the engine.
Old Jan 25, 2015 | 04:01 AM
bensales's Avatar
Yes, I'm familiar with keyless systems, as I mentioned in the original post, my Jaguar has one.
What I don't seem to be able to achieve is actually turning the car completely off without opening the driver's door. The manual isn't particularly clear on if this is possible. Pressing the button just seems to alternate between key position 1 and 2 and never back to 0.
Old Jan 25, 2015 | 05:45 AM
vsnlweb's Avatar
2016 MercedesAMG C63S
There isn't a way to do so other than what the other poster said. The reason for this is when you turn the engine off and dont open the door you may want to still charge your phone, or listen to the radio for a short while. If you dont do anything for like 10 mins I think, the car will switch off completely as to not drain the battery (provided the drivers door hasn't been opened yet). GM cars also do this, where the radio and power stays on until the (drivers) door is opened.
Old Jan 25, 2015 | 07:25 AM
bensales's Avatar
That's unfortunate, but I guess just something else to get used to with the new car. My wife's 2014 Mazda 3 also behaves in the same manner as the Jaguar. Press the button when it's running and it kills everything. In both the Jag and the Mazda, you can give a short press on the button (without pressing the brake in the automatic Jag) and it's the same as putting it back to traditional key position 1, so you can have basic power to things. But another press turns it back off.
Guess I'll just have to get into the habit of hitting the mute button on the radio after P and the parking brake!
Old Jan 25, 2015 | 08:11 AM
vic viper's Avatar
S213
My guess is that most people would want it the way it is instead of instant off.
Old Jan 25, 2015 | 08:34 AM
miketc's Avatar
W205
Put me on this camp, I like to turn off my engine and gather my things while still listening to the radio.
Old Jan 25, 2015 | 11:14 AM
ManiacGT's Avatar
BMW e89 Z4 sDrive 35i & MB S205 C200 AMG Premium Plus
its just the same on BMW. It all turns off when you open the door.
Old Jan 25, 2015 | 01:05 PM
BlackjackM's Avatar
2018 E300 Lux, 2006 Corvette Z51, 2015 Mercedes ML350 (wife's)
I rented a brand new 3er and the radio didn't actually turn off until I got out of the car and locked the doors. Maybe I was doing something wrong but hat was weird. At least we don't have to deal with the ridiculous BMW turn signal stalk!
Old Jan 25, 2015 | 03:00 PM
richardamp's Avatar
2015 C 300
My Lexus would turn off everything in the car as soon as I pushed the button to turn off the engine. I much prefer the Mercedes' behavior.
Old Jan 25, 2015 | 11:56 PM
dnice-1's Avatar
C300 4Matic
I think the benz behaves just like the cars of yesteryear (you know 1990). So when you turn off the car and even remove the key the radio stays on with reserved power once you open the door radio and all aux turns off. Or you could choose to turn off the radio by switch which you could also easily do in the Benz.
Old Jan 26, 2015 | 12:13 AM
vsnlweb's Avatar
Don't think its a yesteryear thing, just a convenience thing. A lot of people, including myself would not like the car to shut of when turning of the engine. Because there are a lot times you're in traffic, or waiting for a train to go by (which takes forever) to take the engine off and not waste gas, but still want some features available.
Old Jan 26, 2015 | 12:42 AM
PeteInGilroy's Avatar
'25 MB GLE 450, w/airmatic
So how does this work with the auto start/stop system. If I stop in my driveway, without doing anything else, won't the engine stop? Then if I put it in park, to shut the engine off what happens?
EDIT: Think I figured it out...the engine turns off, it's just the accessories that remain on? Initially I thought the engine stays on until you open the door...duh!!!
Old Apr 4, 2019 | 11:15 AM
Wayne Jones's Avatar
BMW X1 / GLA 180
[QUOTE=I wouldnt want the car to completely black out (lights and stereo) once you just turn off the engine.[/QUOTE]
I disagree. When I’m sat in thee car waiting for whatever reason, I don’t want to have to sit there with all of the auto features running without opening the door. BMW has a two press feature that turns off the ignition
Old Apr 4, 2019 | 11:18 AM
BMW X1 / GLA 180
Im afraid not. BMW has a two press feature for turning off the ignition
Old Apr 4, 2019 | 11:20 AM
BMW X1 / GLA 180
i absolutely agree. MB is so frustrating with this.
Old Apr 4, 2019 | 11:23 AM
BMW X1 / GLA 180
BMW can have the ignition turned off. It’s a two press feature 😁
Old Apr 4, 2019 | 11:33 AM
benzdude's Avatar
Top Answer: 1
2015 C300 4Matic Sport
It depends on if your foot is on the brake or not. Foot on brake + one press = car starts.
Mercedes Benz has always had the radio remain on after shut down.
Old Apr 4, 2019 | 02:56 PM
CJG's Avatar
CJG
2016 C300 4MATIC
I much prefer the stereo stay on. Maybe I'm waiting to pick someone up. Or, I want to hear the end of a song. Or, I'm just gathering my things. This is the logical way it should work.
Old Apr 5, 2019 | 01:40 PM
Cali4niadriver's Avatar
W205
I really like the MB ignition setup. It’s probably the easiest to use system compared to the other luxury brands I tested. When I’m done driving it’s literally just come to a stop(foot is already on brake) push in with your foot (hold) and press the ignition button and GTFO of the car, that’s it. No parking brake pressed or putting the car in park, it’s all done for you. I also that the radio is still on even after the car is off, I like to check out my phone for a bit when I’m done driving.
Old Apr 5, 2019 | 01:45 PM
benzdude's Avatar
Top Answer: 1
You can park and make sweet love to your girl with music on. 😃👌
Old Apr 5, 2019 | 01:49 PM
fbsdmd's Avatar
2016 C 300 4matic Lunar blue
That's good-In New York State it is illegal to make sweet love unless parked.
Old Apr 5, 2019 | 01:54 PM
benzdude's Avatar
Top Answer: 1
Someone actually wrote a specific law for that?
Old Apr 5, 2019 | 01:55 PM
fbsdmd's Avatar
Maybe.
Old Apr 5, 2019 | 01:56 PM
fbsdmd's Avatar
It could depend on your definition of sweet love
