LED headlight Auto Highbeam doesnt do anything
Is it because they decoded the auto highbeam feature to meet US laws?
If so, can a MB tuner help me enable the auto highbeam feature using a VAG COM?
for it to work, I believe the switch needs to be in automatic and you turn on the high beams. There should be an indicator that lights up (on my w212 it has an A inside a graphic that looks like a light). when it is dark and there are no oncoming light sources the brights should turn on - some overhead street lights can also trigger the sensor so it often doesn't work in the city or on well lit roads.
you can test the high beams by simply turning the switch to "on" from "A" and push the stalk and the high beams should turn on.
Light Switch needs to be in auto then push the left stalk towards the dash. That's it.
Are you in the USA?
However when you have full auto highbeams on, the blue indicator should come on.
