- Mercedes Benz C-Class: Fuel Economy and Type of Gas to Use
Important information to help you understand your Mercedes-Benz
Browse all: Specifications and General Maintenance
Gas for c class (US)
So yes you are correct regarding port upside of the valve. Both Ford & Benz keep the inlet valve clean by pulsing the injector briefly while the inlet valve is open & this keeps the tulip clean. I've been monitoring DI cars in SA & no issues at all.
VAG group seems to have the most trouble with DI & have installed a LP injector in the inlet manifold. Much of what burns onto a valve tulip is VI improver from the engine oil coming down the valve guide plus captive crankcase breather crud.
Benz long experience with building diesels stood them in good stead for DI gasoline.
I heard about VW doing something to try to address the buildup issues, but never read up on it. Are you saying that they added a second fuel injector and everything that goes with it to each cylinder or one in the manifold? Its not that I don't believe you, but more that it seems that would be pretty complex and expensive.
Having said this, I was also wondering how much value detergents in gasoline provide to DI engines, assuming of course the injectors are not getting it on the tulips to keep them clean? Is there a value in the combustion chamber or elsewhere?
Here is the VW/VAG group fix from Golf VII onward: (as I say MB & Ford go the injector pulse on back of tulip route & control valve stem leakdown)
LP injector in the inlet manifold to keep the inlet system clean in conjunction with HP DI . The inlet system is served by a single LP injector.
In the case of a Benz DI. The value of detergent gas is keeping injectors, combustion chambers & valve tulips clean. Combustion chamber cleanliness is where Techron has a clear lead over it's competitors.
While these gasoline additives are commonly referred to as "detergents", and the name has stuck, most are not technically detergents. Just in case anyone actually cares about the chemistry
