- Mercedes-Benz C-Class: How to Install LED Headlights
Step by step instructions for do-it-yourself repairs
Browse all: Lighting Guides
C300 eye surgery and transplant
http://orangecounty.craigslist.org/cto/4860969836.html
The blue arc "welcome' feature in the DRL is done with a blue LED in the base of the light guide. Here's a good description:
http://www.al-lighting.com/press/sin...0738c80087a183
The blue led you found could well be that diode.
I'm not sure how much work you've done in the past with high powered LED systems, so don't take my advice the wrong way, but If you've wired those array chips into a pure 12V supply without any PWM and current limiting circuitry then it won't take long before something overheats and blows up. Drive current and thermal management on high output chips like that is a tricky business. Vehicle systems are notorious for unregulated circuits; your best hope is that whatever you've wired into is a balanced power circuit but the only way you're going to know that for sure is if you have a logging multimeter and tested it. You're much safer to integrate your own stable DC power supply.
Anyway, I admire your ingenuity and wish you the best of luck. Keep us posted on how things behave over time. If you have questions, don't hesitate to ask - I'm more than happy to pass on any knowledge I've picked up over the many years that I've been building DRL and lighting systems.
thanks for the advice. It was just my guess based on my observation. I am anything but an expert on LED :-) btw, when you said the led would blow up, you don't mean like exploding, do you? that would be a safety issue
. They do get extremely hot though - never underestimate the ability for a high powered diode to set something on fire. Yes, diode voltage would very rarely be exactly 12V. You need to know the specs of the LED you're using. High powered chips like that are built up by using arrays. The voltage required to drive them depends on that configuration and this can be anything from <3V to >34V.
If you still have one of the lights out, can you take a good picture of where the bumper and the fender meet near the trunk? The place where the dealers have to adjust to fix the light/bumper alignment issues. Thanks!
you mean taking a pic with the light housing out? ahh...I just put them back in :-( sorry. But from what I saw, it's all metal and part of the car body. Nothing they can adjust. What I'm guessing is they're removing the lights and repositioning them a bit. I think that's all they can do. Personally, I don't mind, as nobody is gonna come that close to inspect it.
That's hilarious. Cops might pull me over to tell me that "Do you know one of your tail lights is out?", and I'll be like "Which one?"
But it's good for you, though. If you have it and you like it, then you won't have to go thru too much trouble like I do to change it :-)
I just bought a CPO c300 that comes without the lighting package.
Can you help me to upgrade it?
What things should I buy? I really don't understand.
Thank you.
