Stop/Start not working?
Any ideas on what the problem could be?
They are dying to find out how you did it! (A couple of them have already showed up over here.)
1: Install New Software Update for ABS braking system and 2: Replace the Air filter with an updated design.
I'm very glad to say that having now driven the car for last 2 weeks in Eco mode, the problem does appear to have been resolved and now I also notice that when I park the car, the hand brake applies itself automatically. This was not the case previously and did required my intervention to set it. The engine is also now quieter during acceleration and I hear less of 'a growl'
Thats an interesting side note about the growl on acceleration, I've got that and it's not a nice sound, interesting to know it could be sorted with a new design, started to think there was something wrong with the engine as it sounds like a knock at low speeds it's that horrible a growl.
I've since sold my Mercedes and now have a new VW Golf with Start/Stop and so far it works fine, in fact it works better because it has radar 'Adaptive Cruise Control' that senses traffic ahead, so as soon as the car in front moves off in a line of traffic, the engine starts up immediately saving a few seconds each time.
Cheers
After gas station, while I was at the intersection waiting for green light, the engine is keep running. weird...
I didn't use any A/C or Heater climate control, no radio, CD...so it won't be the battery charging issue.
I checked the Eco Start/Stop switch and there's no green light.
I pressed that switch several times but nothing changed (still no green light).
Once I got home, I shut off the engine then started the engine again then the green light illuminated.
When I stopped my car inside of the garage the engine shut off as usual....normal activation of Eco Start/Stop function
What I suspected was, not 100% sure tho, normally I press the Start/Stop button once(1) when I started the engine but today I pressed it 3 times instead of 1.
1st press - radio on Mode, 2nd press - Electronic On mode then 3rd press - engine starts...
Any advise?
You need to have your seatbelt buckled to activate it. Mine will be yellow until I click my driver seatbelt then it stays lit green and stop start works. Also stopped working because battery wasn’t putting out enough power because it was old. Just my two cents
