new C300 with Engine noise
Rating: Thread Rating: 2 votes, 3.00 average.
Old Sep 12, 2016 | 09:29 PM
  #326
Shadwell's Avatar
C300 S205 AMG, GLA 45 AMG
Originally Posted by SoDakBenz
This glide function freaked me out at first til I realized what was going on. It still is a better drive than the gla. They had me drive one of those and it had the DCT and when u first take off it feels like your driving a manual transmission with the lag til the second clutch engages
Weird, our GLA 250 AMG has bugger all delay between shifts, its smooth and intuitve.. runs very strong with a tune too.
I fitted a GFB DV+ which does improve the transmission feel further... as the boost is held up slightly between shifts so the reintroduction of power is from a higher level and hence smoother..
Old Sep 17, 2016 | 11:53 AM
  #327
SoDakBenz's Avatar
2015 C300 Sport 4Matic, 2014 C300 Sport 4Matic
Just got my car back from getting the engine noise taken care of. So much quieter. Still annoyed they couldn't find the rattle in my driver door/dash area. It wouldn't replicate for them or me but literally the moment I picked it up it was back. They pulled the door panel and refitted no fix.
Old Sep 20, 2016 | 04:54 PM
  #328
cjaredscott's Avatar
19E450A, 16C450W4, 16RRS SC Dynamic, etc
Hi guys, I didn't know about this issue before this thread, but after reading it, I went out to my car (2015 C300 build 03/15) and a faintly heard it, but only for the first maybe 10-20 seconds of a start (warms up pretty quickly in the warm weather) -- hence why I never noticed it before. After, I brought my car to the dealer, mentioned this, and turns out I need to have my pistons replaced, just like virtually everybody else in this thread. Mine's a lease which will go back just at the end of the car's new car warranty, so I'm not sure how much of a difference for me it would have made, but for the next owner it could have made a big difference, and maybe I'd end up on the side of the highway stranded, so best to get it done. Thanks to all for making me aware of this issue!
Old Oct 30, 2016 | 06:45 PM
  #329
chicago-guy's Avatar
2015 C300 sport
Trying to get a fix on whether my 2015 C300 (4/2015 build date) has the wrist pin issue or something else. What I hear from my engine (cold start, 2,000-1,000 RPM) doesn't quite sound like what I hear in earlier posted sound clips on this thread.
Recorded this today ; similar to what anyone else with the wrist pin issue heard from their engine? Thanks
Old Oct 30, 2016 | 07:12 PM
  #330
Mike5215's Avatar
2016 C300
I can tell you my 2016 C300 doesn't sound like that at all. I'd get it to a shop ASAP since if it's the wrist pin issue it causes progressively more damage to the cylinder walls with time.
Old Oct 30, 2016 | 09:52 PM
  #331
Mikey53's Avatar
Veteran: Air Force
2016 C300 4Matic traded in for a 2022 E450 Coupe
https://youtu.be/SzD7P5TXiGk
Sounds like you have some kind of problem for sure. Mine doesn't sound like that.
Old Oct 31, 2016 | 07:37 AM
  #332
StanNH's Avatar
2015 C300 Sport: Palladium, Premium, Multimedia, Leather, BLIS
Personally, I don't think you can get an accurate diagnosis based on a video. Just take the car into your dealer and let them check it out for you. If they can hear any noise that shouldn't be there, and conclude your engine has the wrist pin issue, they'll repair it under warranty.
Old Nov 1, 2016 | 03:42 PM
  #333
C230WAK's Avatar
05 C230, 15 C300
I have a 2015 C300. It was made 1/2015 and it has the same sound when I start it up. Let us know what they say when you take it in. To be honest I'm hoping it is nothing because I don't want the dealer opening the engine. I already had a drive shaft replaced for a grinding sound in reverse. What I don't understand is that our engines are from Germany and I don't think they were all new. I thought they were using them in Europe for over a year.
Old Nov 1, 2016 | 07:27 PM
  #334
2015 C300 sport
In she goes
Will do @C230WAK. It's scheduled to go in tomorrow. An alternative suggestion for the cause, that I heard today, is tappets needing adjustment. That would be a relief, but I don't see much mention of those on related threads so I'm expecting the worst (wrist pin issue). Thanks for commenting. Watch for follow-up.
@StanNH, thanks for replying, yeah I was already planning to take my car in, but I like to get as much advance intel as I can gather, and there's a ton of great experience on this forum.
Old Nov 1, 2016 | 07:34 PM
  #335
2015 C300 sport
@CJaredScott, Did you get it repaired? If so, how long did it take? Any negative outcomes -- other than loss of use of your car for a while?
Old Nov 2, 2016 | 09:06 AM
  #336
StanNH's Avatar
The problem with all of this is that MB has never indicated just how widespread the issue is. The TSB covers a large range of vehicles, but no one knows the numbers of cars that have had, or may have, the problem. The latest CR reliability survey does not indicate an unusual number of problems reported for 2015 engines, so it may not be as common as feared. I did have my dealer check for wrist pin sounds during my last service, and they found no problem. My guess is that any C300 in for service will have the engine routinely checked for this under the TSB.
Old Nov 2, 2016 | 02:53 PM
  #337
gfmohn's Avatar
2021 E450, 2020 C43, 2015 C300, 2007 C280
German design problem, not an American assembly problem
Originally Posted by C230WAK
I have a 2015 C300. It was made 1/2015 and it has the same sound when I start it up. .... What I don't understand is that our engines are from Germany and I don't think they were all new. I thought they were using them in Europe for over a year.
Originally Posted by StanNH
The problem with all of this is that MB has never indicated just how widespread the issue is. The TSB covers a large range of vehicles, but no one knows the numbers of cars that have had, or may have, the problem. The latest CR reliability survey does not indicate an unusual number of problems reported for 2015 engines, so it may not be as common as feared. ....
C230WAK. you assume that engines made in Germany are okay. Other commenters in this and other threads have stated that German engines have this problem too. It is said that this is a world-wide design problem by the mighty Mercedes engineers in Germany, not an assembly problem by American workers. I have quoted these other commenters, and no one has contradicted me.
I have also read that early production models of the C-Class had engines and transmissions made in Germany. At some point unknown to me, the Alabama factory started using engines and transmissions made in a joint Mercedes-Nissan-Renault plant in Tennessee. My C300 was delivered in early 02/15, with a build date of 12/23/14. I believe (but am not certain) it has a German engine. It had the wrist pin problem. It was rebuilt in 11/15 and has been smooth and trouble-free since.
Old Nov 3, 2016 | 06:42 PM
  #338
2015 C300 sport
Engine tear-down it is
Confirmed as the wrist pin problem at the dealership. They're supposed to start the engine tear-down today, parts due in tomorrow. There was even mention of the possibility of having the job done by the weekend, but it seems to me like they should keep it at least an extra day to put some miles on it and confirm that there are no leaks or other side-issues?
I also recall a few mentions further back in this thread about the technician putting 50-100 miles on the car post-repair to ensure all is well. Think I should insist on that if it's not already in the plan?
(On the plus side, they gave me an E-class as a loaner. )
Old Nov 4, 2016 | 07:35 PM
  #339
C230WAK's Avatar
05 C230, 15 C300
Does anybody know if the wrist pin issue is causing damage to the engine or is it just causing the noise?
Old Nov 4, 2016 | 08:03 PM
  #340
Mike5215's Avatar
2016 C300
Yeah, the noise is caused by the pistons slamming around the cylinder walls. If it went unrepaired long enough it could cause more damage.
Old Nov 4, 2016 | 08:10 PM
  #341
JIMSHANN's Avatar
C350e with Comand, Vision Package and seat package, 2017 Mini Cooper S 7
I've just ordered a new C350e and the delivery has been put back 3 months. My dealer says it's because a "new" engine is being fitted.
Maybe MB has realised it is a big problem and are fixing it.
My dealer couldn't give more details.
In another part of this Forum I was advised that it could be due to this "Wrist Pin" problem.
Old Nov 5, 2016 | 12:52 PM
  #342
2015 C300 sport
Engine rebalance during wrist pin repair?
My 2015 c300 has about 8,700 miles on it and undergoing repair for the wrist pin problem. I am told there is no cylinder damage, which is a relief, but I wouldn't have wanted to wait much longer. (I only got the car a few months ago, which is why the repair wasn't done when the mileage was lower.) They are replacing the pistons, connecting rods, and bearings.
My biggest question at this point regards engine balance. If the weight of the new components is different than the old -- and that seems likely to me since the replacement wrist pins will be a slightly different size than the old ones, for starters -- shouldn't the technicians be throwing the cam shaft onto a balancing machine to make sure the resulting rotating weight difference is neutralized? I asked about that, and it's my impression that engine balancing is not part of the MB guidelines for this particular repair. Should it be?
Old Nov 5, 2016 | 02:00 PM
  #343
Mike5215's Avatar
2016 C300
I'm not sure about balancing, but I would think they'd re-hone the cylinder walls and replace the piston rings.
Old Nov 5, 2016 | 11:15 PM
  #344
2015 C300 sport
Thanks, I'll ask about that.
Old Nov 5, 2016 | 11:22 PM
  #345
rustycruiser's Avatar
2015 W205
I asked the shop manager if they honed the cylinders when they rebuilt my motor in Jan, and he said no.
Old Nov 7, 2016 | 04:48 PM
  #346
topsider's Avatar
2015 C300 Sport 4MATIC
I have this issue and am at 25.8k miles and my car is running fine
Old Nov 29, 2016 | 12:49 AM
  #347
seattlec300's Avatar
2015 C300 4MATIC
bringing this back from the dead since i just bought a used c300 a month ago...
i hear a faint rattling or knocking noise rarely at idle or low rpm's. honestly, i probably wouldn't have even noticed it if i hadn't read this entire thread and listen for it constantly.
took into the dealership and they told me that my engine does not have the wrist pin issues. they didnt take apart the engine, they just simply listened for it. i was told the head technician, who has seen this issue before and is knowledgeable was who took a look at my car.
should i be satisfied with this result or should i push them to take a deeper look?
Old Nov 29, 2016 | 07:39 PM
  #348
2015 C300 sport
What's your build date? Anything earlier than 5/2015 is apparently suspect for the wrist pin thing. BTW, when you say "rarely at idle or low rpm's" do you mean the sound occurs occasionally, or do you mean it occurs most often at high rpms and less often at low rpms/idle? Also, is the engine cold or warm when you hear it, or makes no difference?
The techs at any MB dealership service garage should be very familiar with this issue by now, and I see no reason to doubt what yours says, but if your engine build is pre-5/2015 and you hear the rattle when the engine is cold somewhere between 1,000 and 2,000 RPM at idle and low speed, you may want to get a second opinion if another dealer is within range.
Or, of course, path of least resistance is to ask your tech to identify what IS causing the noise you are hearing, if you can get it to occur with him in the car
Old Nov 29, 2016 | 07:52 PM
  #349
PeteInGilroy's Avatar
'25 MB GLE 450, w/airmatic
You need to drop your car off the night before so the tech can hear the engine when it is cold. After a minute or two the wrist pin ticking issue is no longer present.
Old Nov 29, 2016 | 08:07 PM
  #350
2015 C300 sport
Realized I never wrapped this up, FWIW. Car was back in record time, like 5 days . Tech put 150 miles on it (with my permission of course) to make sure all was well. Lonnnnng list of parts replaced. End result: the rattle is gone, and the engine sounds a bit gruffer than it did, which doesn't bother me actually, and performance seems a bit better, both in terms of acceleration and possibly even a tiny bit in mpg. (I could be imagining both of these -- i didn't benchmark mpg before the operation unfortunately, and the transmission control unit may simply finally be realizing that I prefer not to dawdle away from a light regardless of what driving mode I'm in and adjusting accordingly.) Regardless, happy to have caught the problem early thanks to earlier posts in this and similar threads.
You have already rated this thread Rating: Thread Rating: 2 votes, 3.00 average.
