Does anybody know how to turn off these lights?
Old Mar 17, 2015 | 11:08 PM
Xzer0's Avatar
2015 C300 4Matic
I turned off all the lights and locked the car, but it seems like the driver's side headlights and taillights are still on. Is this normal? Anybody knows how to turn them off?
Old Mar 17, 2015 | 11:13 PM
BlackjackM's Avatar
2018 E300 Lux, 2006 Corvette Z51, 2015 Mercedes ML350 (wife's)
Yes turn your headlight switch back to "auto" as you have activated the drivers side parking light.
Old Mar 17, 2015 | 11:14 PM
Xzer0's Avatar
2015 C300 4Matic
Xzer0's Avatar
2015 C300 4Matic
Ok, thank you
Old Mar 17, 2015 | 11:39 PM
joshg1001's Avatar
2017 E300
those are parking lights, we dont use them in the US but they are popular in Europe where people keep them on when parked so cars that drive by won't hit them
Old Mar 17, 2015 | 11:45 PM
Tjdehya's Avatar
2023 AMG EQS
It is also the only way to turn off your headlights at night when the car is parked and running.
Just don't forget to turn them back to auto when you get out or they will drain your battery overnight.
Old Mar 18, 2015 | 08:43 AM
BenzC400's Avatar
AMG CLE 53
The owners manual says that the parking or standing lights will turn off automatically as the battery is drained so that the car can be started next time. I'm not sure I would depend on that though.
From the owners manual:
Parking lamps
If the battery has been excessively discharged,
the parking lamps or standing
lamps are automatically switched off to
enable the next engine start.
Old Mar 18, 2015 | 12:39 PM
Tjdehya's Avatar
2023 AMG EQS
Parking lamps
what is your point?
I said "Just don't forget to turn them back to auto when you get out or they will drain your battery overnight."
Then you posted exactly what I said from the owners manual "If the battery has been excessively discharged"
Are you saying that excessively discharging your car battery for no reason is an ok thing to do and you shouldn't worry about leaving your lights on?
Old Mar 18, 2015 | 02:41 PM
emregogan's Avatar
mercedes w205
In my other German car if you park the car and you leave the signal on left or right then it lights up if you put the signal handle in the middle it should switch off
Old Mar 18, 2015 | 02:57 PM
BenzC400's Avatar
AMG CLE 53
what is your point?
No offense intended. Just trying to help the OP with the info from the manual.
Old Mar 18, 2015 | 09:07 PM
Xzer0's Avatar
2015 C300 4Matic
Thank you for the information
Is it possible to turn on the lights that are on the other side instead of these?
Old Mar 18, 2015 | 09:43 PM
BlackjackM's Avatar
Yes just look at the switch, it will be pretty obvious.
Old Mar 20, 2015 | 11:12 AM
mihaelb's Avatar
B200T
Always wondered what those were for (but never remembered to look it up). Thanks for the clarification!
Old Jan 19, 2017 | 01:34 PM
whiteC3002016's Avatar
2016 Mercedes C300
I just saw this yesterday and thought it was broken
Old Jan 19, 2017 | 04:31 PM
DapperStyle's Avatar
2014 C300
Just leave the switch on auto, no need to fuss with it.
Old Jan 19, 2017 | 05:30 PM
kleinebin's Avatar
W214 AMG Line
If your the last vehicle in a row of parked cars on a dark street the parking lights will prevent you from being hit from behind, especially if close to an intersection.
Old Jan 19, 2017 | 06:35 PM
vladarh's Avatar
E350e W213
...or the first!
Old Jan 19, 2017 | 07:45 PM
kleinebin's Avatar
W214 AMG Line
Indeed
Old Dec 10, 2019 | 06:25 PM
domwild's Avatar
C220 CDI W204.008 2007
It is a feature for European small roads BUT is also a flaw on some Mercs, like mine, to randomly switch the RH parking lights on or even flicker. It has nothing to do with the SAM or some other electronics, it will cost you a new light switch and it Oz that is a AU$500 disaster.
It may pull out easily or it may be extracted via the panel on the LH side.
