Creaking wagon
Old Apr 3, 2015 | 04:11 AM
bensales's Avatar
Creaking wagon
Anyone else's estate/wagon creaky and groan? Seems like whenever I drive around something that involves sharp changes of direction and ramps, like a parking garage, there's loads of creaking and groaning from the back of the car. I suspect the car is twisting and the seats and load cover are moving.
Even does it over bumpy roads, which in the UK, makes for a pretty noisy drive.
Old Apr 3, 2015 | 04:20 AM
Eilers's Avatar
S205
None here.
In fact my experience is the opposite. The car feels very stiff and has a remarkable quiet cabin, even on rough and gravel roads.
Old Apr 3, 2015 | 04:21 AM
ManiacGT's Avatar
BMW e89 Z4 sDrive 35i & MB S205 C200 AMG Premium Plus
Mine does this a little, intermittently. Certainly nothing major and I don't notice it until I'm parking on a ramp or whatever. I suspect its the rear seats as on the odd occasion when I've pressed against the rear seat backs they creaked a little. Its probably something to do with the seat hinges or latches needing a little lubricant. The car feels perfect in all other ways. Its a long car and there's bound to be some minor twist in the chassis, especially with the pano sunroof which will weaken the chassis a little.
I've told the dealer but my experience with dealers is that while they solve one thing, they create another issue, taking everything apart etc.
So I'm waiting for better weather when I'll have someone in the car and help pin down where its coming from then apply lubricant.
I'm determined that any minor gripes (and this is minor) with this car I'm going to solve myself as my experience with the last car, taking it in for every little thing, means you end up with a car that rattles even more in the years to come.
Old Apr 3, 2015 | 04:24 AM
bensales's Avatar
It does seem to have gotten worse. I've had the car for 2.5 months now, and it's done 3000 miles.
I guess it could also be the pano roof creaking.
As it's got to go back again about the comms, I'll get them to see if there's anything that needs greasing.
Old Apr 3, 2015 | 04:39 AM
ManiacGT's Avatar
If some have it and some don't its probably related to the spec of the car or a build date/change. I wouldn't worry, it's likely a minor tweak and the more people that report it the easier it will be to deal with at the stealers. Things like this seem worse because the car is so quiet otherwise.
For now, stick on some tunes and just remember to mention it to the stealers if you want them to sort it.
Old Apr 3, 2015 | 04:48 AM
ManiacGT's Avatar
Oh one final note though...
If the dealer does sort it for you, ask them what they did and pop it on here would you, it might help myself and others facing the same noise.
If I find it first, I'll let you know also.
Old Apr 3, 2015 | 08:50 AM
StanNH's Avatar
2015 C300 Sport: Palladium, Premium, Multimedia, Leather, BLIS
Very unlikely. There have been no reports of any noises, mechanical or wind related, attributed to the roof.
My guess is that some panel or seat part is rubbing as the car body flexes.
Old Apr 3, 2015 | 09:53 AM
W124-FTW's Avatar
S205 C200 Sport
I've noticed the occasional noise from the rear seats but as I've got child seats in there most of the time, I've assumed that's been the source.
Wind noise from driver's door is a much bigger issue for me personally.
With regards a constant groaning noise, that normally comes from the occupant of the front passenger seat
Old Apr 3, 2015 | 10:55 AM
ManiacGT's Avatar
Having just done a long run today I agree the incredibly annoying noise from the passenger seat is by far the worst thing. Sadly even MB can't help me there
The odd creak from the back somewhere is the only thing I can report, thankfully no wind noise etc
Old Apr 3, 2015 | 12:37 PM
rustycruiser's Avatar
2015 W205
I am hearing creaking from the front right hand side spring/shock absorber. Only after the car is warm/driven for a while for some reason. By the time I get to work (or home in the evening), evry bump or turn I make is creaky. Especially noticeable going over speed bumps.
Old Apr 3, 2015 | 12:38 PM
riku2046's Avatar
MB C250 estate avantgarde S205, BMW 528i F10
It is happening in my S205 as well. After 2 weeks of investigating on my part, I have pinpointed the creaking is coming from the folding rear seats on mine. When I drive over a speed bump or making a turn...etc, the stress in the chassis is making the seats creaks. I am guessing it is the seat frame....
will bring my car to the dealer next week. Hope they can fix it
Old Apr 3, 2015 | 01:03 PM
Eilers's Avatar
S205
Doesn't have to a be a quality issue. In general, with stiffer suspension and/or lower profile tires, expect more creaks from interior panels etc.
I've had several cars in the past which only started creaking after i installed big alloys or lowered suspension
Old Apr 3, 2015 | 01:37 PM
StanNH's Avatar
Just tell her to be quiet and stop nagging.
Old Apr 3, 2015 | 03:38 PM
mikeyw's Avatar
S205
I did get the odd creak at low speed over pot hole and curbs etc. turned out to be the luggage cover I think.
Old Apr 5, 2015 | 03:02 PM
ManiacGT's Avatar
I narrowed this today, to the clamp that holds the two part seat in place.
I put a smear of general purpose grease on both the seat clamp and the part on the car it clicks on to.
Noise gone.. So far.
Old Apr 5, 2015 | 05:32 PM
deonsand's Avatar
w205
can you post up the photo where you apply the oil on the clamp.
I had those issue too
thanks in advance
Old Apr 6, 2015 | 11:09 AM
ManiacGT's Avatar
I can confirm the creaking has gone for me. Just for you and anyone else this might help, please see the two areas I placed a thin smear of grease (and I mean really thin so there's hardly any on to get on clothes if the seats are folded etc but clearly enough to make the surfaces move a touch without noise).
Old Apr 6, 2015 | 01:14 PM
bensales's Avatar
Thanks for that. I'll lube it up (fnarr) before I head to the station and it's multi-story carpark tomorrow and see if that sorts it. I'll do the catches for the load cover as well, as I've had that out a few times.
On a side note, it's a neat trick how the load cover can slot into the back of the seats when they're down so you can attach the luggage net to the roof to keep a load from coming into the front cabin.
Old Apr 6, 2015 | 01:35 PM
ManiacGT's Avatar
Hopefully this will sort it for you and anyone else. I've been tootling around in total silence today.
If we're talking neat tricks, more impressive to me was when lowering the back seats the front ones moved forward on their own to enhance clearance and load volume.
Very cool.
Old Apr 6, 2015 | 01:36 PM
bensales's Avatar
Ha! That one caught me out the first time. Dropped the seats and filled up the back to go to the tip. Toddle round the front and couldn't get into the car, I'm well over 6 foot and the seat is normally a long way back and as low as it'll go. Spent ages trying to figure it out :-)
Old Apr 6, 2015 | 01:54 PM
bensales's Avatar
Awesome, that's sorted it! A little grease on the seat and load cover catches and noise seems to have gone.
Never ever needed to do that on a car before, mind.
Old Apr 6, 2015 | 01:58 PM
ManiacGT's Avatar
I'm the closest you'll find to an expert on noise sorting because my BMW z4 has been a noise fest continually for years. Every month a new rattle or creak to find.
That's a convertible tho... With lots more moving parts.
Old Apr 6, 2015 | 06:03 PM
deonsand's Avatar
w205
thank you very much ,
it is all sort out
creaking sound is gone
Old Apr 7, 2015 | 05:58 AM
ManiacGT's Avatar
Brilliant, glad I could help. Looking at the mechanism it seems there's a little hard plastic/rubber on the seat lock and I think its that rubbing against the metal loop on the car that caused the noise. Its possible a change in supplier or build step has meant no greasing or a material change causing the noise. Even environment. In any event hopefully thats that sorted with just the tiniest amount of grease. In fact you could probably wipe it clean now and it would still be ok, to ensure no grease gets onto your clothes if you ever drop the seats.
Old Apr 7, 2015 | 08:37 AM
riku2046's Avatar
Thank you ManiacGT so much! I will try it on my S205 tomorrow!
