Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior Guides
- Mercedes-Benz C-Class: How to Install Dash Cam
Step by step instructions for do-it-yourself repairs
Blackvue Install
#76
#77
Hi guys.
When buying the camera from the blackvue website there's options to select the memory capacity.
Since it works with an sd card,the memory choice(different prices)means that it comes with a 16 gb for example or that's the size of the memory card it will accept?
Cheapest option is 16 gb,but does this mean that it will only accept 16 gb cards?
Thanks.
Thanks.
#78
Hi guys.
Thanks.
Thanks.
#83
Hi guys.
Thanks.
Thanks.
On a side note I'm looking at 650S now, just debating if I want 1 or 2ch. Will probably get the magic power thing for the parking feature too.
#84
2016 Mercedes c200 w205 auto
Screen issues
Great info thanks as just had 2ch blackvue and power magic pro installed and the guy used front fuse box and wrapped around fuse. After week of no issues we now are losing command screen, Bluetooth etc ... very hit and miss if works but seems to be getting worse. Could it be linked to the dashcam install or has anyone else had issues with command etc... we have 2016 W205 C200 auto. Thanks and great info...
#85
W205 C250 Sedan
Try High Endurance SD cards, they are specifically for these type of high write cycles in dash cams etc.
http://www.lexar.com/products/memory...S-I-cards.html
#86
#88
would following this guide be appropriate? I want to wire it to the trunk.
#89
Here's the issue:
These devices that supposedly shut off when the voltage reaches a certain level apparently cause issues in the MBs, over time. I had a device installed that was set to shut off at 12Vs and had an increased number of low voltage warnings, as well as other COMAND issues.
Dealer said that my draw when the car was off was WAY too high... additionally, there were several instances noted by the dealer where the voltage reached 12v's and the unit did not shut off, further draining the battery.
The dealer wired a brand new, fuse to an open location in the driver's fusebox, to the switched rail behind the fusebox. It cost me 2 hours labor + parts. All in all, it was WAY worth it as it is safer than a piggyback and all of my other esoteric electrical anomalies went away.
I also wired my radar detector this way.....
A2A
#90
I actually had my dealer wire an entirely NEW fuse into the fusebox for a switched circuit, and then wired a battery backup (Cell-link) to that for power upon car shut off.
Here's the issue:
A2A
Here's the issue:
A2A
It sounds like your voltage controlled relay device was defective or improperly configured.
#91
So I went ahead and added a fuse tap to the analog clock fuse socket in the front driver's side fuse box. It worked perfectly so far. No anomalies with the clock or any other electronics. It took me about 15 minutes and one cold beer to complete the instal. Using a plastic trim removal tool made this job much easier than it could have been.
If you are using a fuse tap remember to be selective in the circuit that you choose. It needs to be constant on, but it should also be < 10A. Most fuse taps are not rated any greater than 10A. Make sure to check the rating for the component you use and do not exceed it.
My camera runs the parking mode with a timer instead of a V regulator. I'm playing conservative and shutting it down at 6 hours. I'll try a longer duration once I've confirmed that 6 hrs will not draw down the batt.
#92
Originally Posted by Mr. J
A current draw is a current draw.
And none of those current draw devices have worked as well as this setup and I get 48-72 hours of backup.
#93
My advice is that you should always keep fuse taps usage limited to relay trigger lines or for very low amp devices.
#94
That's the way to go. Not many people realise that the cell-link battery systems do draw quite a lot of current and have a known tendency to melt stuff like fuse taps or inappropriately gauged wiring. Get a proper independent fuse block if you run those (i.e. don't just tap into existing circuits).
Not an issue if you're only running the camera. Those things draw milliamps, but other battery backup systems (as per above) can certainly surpass the load on a standard 10A circuit.
#95
#98
Since I installed a 2ch one with a power magic, my battery is constantly flat. Jump start so far hasn't been required but the dashboard displays the "stop the car, keep the engine running" message all the time.
Not sure it's because of the setup or because my battery is 5 years old. Also, I only drive up to 1hr / week, so that's probably not helping my case either. I went to a local auto store and they checked the health of my battery and then told me to just go for a long drive (<1hr), so the battery seems still ok.
#99
thanks
#100
Parking mode is on until power drops below 12V. Mine is auto.
