Flat tire
1) Was I right to bring my car to dealer with such rather easy problem ? I might bring my car to near tire shop...
2) Any guess for estimation ? Dealer did not answer to my question about cost to replace tire or even basic warranty thing.
This is the problem with run-flat tires...they can't be repaired so you have to buy a new one (probably $200+). And if you were half way through the wear of the tires, would you buy one or go ahead and replace all four?
I use tirerack for my tire pricing. I've been able to get install prices as well, but i can't remember if that was only after purchasing.
Weird pic, as the bead is popped out. I thought runflats had a specially designed bead to prevent the tire from breaking the bead even after a loss of air pressure?
Expect $345-$400 for the tire alone. If you need a rim, get some Vaseline!
I picked up a nail in my runflat at 2K miles. I was 1 min from work when my sensor went off, and never drove on the tire with no air. So I plugged it, and have been driving on it for the last 3 months with no problems.
https://mbworld.org/forums/c-class-w...500-miles.html
