Sounds from door seals
Anyone else notice this? My car doesn't even have 1000 miles on it yet but i'm noticing small sounds from the door seals when i go over small bumps or enter a driveway. It's almost as if the chassis is flexing and I can hear the door seal adjusting, specifically in the front two doors. I have the wind noise issue as well, make me think that either the doors aren't adjusted tightly enough or the rubber is just not doing a good job sealing the doors.
Received 2,031 Likes
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
Also you can apply some armor all to the rubber seals and that can get rid of some of it
Even better would be Aerospace 303 spray or a small amount of pure silicone lubricant. Anything with distillates will degrade the rubber there (though it would solve the noise and look shiny)
so just confirming this is not a defect? does all car have it
i am just reaching 900 KMs on mine and i started to notice this earlier this week.
It is becoming increasingly annoying as i constantly notice it.
Is there a similar solution for the wind noise or can dealer help fix the matter?
Let me know
Let me know
BMW e89 Z4 sDrive 35i & MB S205 C200 AMG Premium Plus
I had this recently with the rubbers around my pano roof. Rubber lubricant resolved it. All cars get this now and then, my z4 is convertible and covered in seals that tick and squeak without regular rubber lube.
2015 C300 RWD
Depends on the base of the product. I wouldn't use wd40, but something like:
http://www.super-lube.com/silicone-l...fe-ezp-53.html
Or
http://www.goldeagle.com/product/303...ace-protectant
The first one is also good to use on pool parts, other lubricating, should be used sparingly. Small tube should last a lifetime. The second one has a lot of car uses.
Or
