Weak Feet Vents
Old May 20, 2015 | 11:21 AM
vancity604's Avatar
C300
Weak Feet Vents
The foot air vents are really weak on my car. If I change the vents to "feet only", I can still barely feel like on 7. If the vents are shared between feet and anything else, there's like nothing coming out on the feet.
Anyone else notice this?
Old May 20, 2015 | 11:54 AM
ManiacGT's Avatar
BMW e89 Z4 sDrive 35i & MB S205 C200 AMG Premium Plus
Bearing in mind of course that the feet vents serve both the front and rear occupants... ( check under your seats )
Old May 21, 2015 | 12:14 AM
gfmohn's Avatar
2021 E450, 2020 C43, 2015 C300, 2007 C280
"Feet only" setting isn't really
I had the same feeling when it was still really cold here. I merely had to shift to "feet only", but I didn't have to increase the blower speed. That may be because, when it gets cold, I turn off the A/C outlet for the rear seat. That's the one between the front seats. It's A/C only; the heat for the rear seat comes out of the floor vents.
You should also know that the "feet only" setting turns off only the center vents in front. It doesn't turn off the side vents. You can try closing the side vent on the passenger side when you don't have a passenger and partially closing the side vent on the driver side. To take care of fogging, MB intends the A/C to be kept on year-around anyway. Both in my previous 2007 C280 and my present C300, I have found that in cold, damp weather, the A/C is indeed necessary to prevent fogging of the side windows.
