450 ECU Tuning Results
Old May 21, 2015 | 04:17 PM
SALES@OETUNING's Avatar
SPONSOR
OE Tuning C63 AMG
OP can be found here: https://mbworld.org/forums/gl-class-...ml#post6440367
After tuning GL450 3.0L V6 Biturbo we saw huge gains of +124wTq @3600rpm and +106wHp @4600rpm to all 4 wheels on a 4×4 Mainline Dyno. An unmodified GL450 running CA91 premium pump fuel was dyno tested. Gains can be seen on the pictured graph below, the unmodified Baseline (Blue) vs OE Tuning ECU Tune (Red).
Power and performance ECU upgrade from OE Tuning includes:
Increased Boost Targets (16psi)
Fuel Adjustment
Improved Throttle response
Top Speed Limiter removal
Raised Torque Limits
Tune price is $1195 and does require the ECU be removed and sent in for modification. Please contact sales@oetuning.com or call +1-818-574-5075 to order.
Attached Thumbnails 450 ECU Tuning Results-2015-gl450-v6-biturbo-ecu-tune-dyno-tested-600.jpg
Old May 22, 2015 | 03:52 AM
Stupidnewbie's Avatar
C400
Is there is anything preventing these same numbers in a C400?
Old May 22, 2015 | 03:59 AM
w62820616's Avatar
C450 | BRABUS 600 AMG GT | C63S
HI,
Is it safe? I can expect for this tune for the coming up C450AMG?
Can I drive to your place for the installation?
Regards,
Li
Old May 22, 2015 | 01:16 PM
SPONSOR
OE Tuning C63 AMG
C400 and C450 ECU Tune
We expect same results from tuning C400. We are looking for a local SoCal car that would like to confirm dyno results for C400, C450 and C300 tunes.
Originally Posted by w62820616
HI,
Regards,
Li
Yes. We tested the tune to operate within safe operating guidelines before public release. We can install the tune at our shop in Huntington Beach while you wait. Please call +1-818-574-5075 to make an appointment.
Old May 26, 2015 | 12:10 AM
dreamerak's Avatar
CLA 250
Fuel Adjustment
Huge power increase under the curve, can't wait to see 0-60 and 1/4 mile times..
Old May 26, 2015 | 12:54 AM
PeterUbers's Avatar
Hmm ... Initial vendors were identifying a much more conservative tune
This is a big bump
How safe can this be on the drive train and engine?
Old May 26, 2015 | 01:30 AM
TopGun32's Avatar
16 psi..on 91 oct. this is good news if OE stands behind the tune.
im running 14 psi with some gallons of e85, and car is strong.
i have OE on my coupe and love tune.
Old May 26, 2015 | 11:56 AM
C400
Email sent.
Old May 26, 2015 | 06:18 PM
SPONSOR
OE Tuning C63 AMG
C400 ECU Tune
This is a big bump
From testing we have seen the engine operate safely once tune is installed. No adverse effect to the transmission either.
Email sent.
Replied
Old May 26, 2015 | 11:13 PM
RA7822's Avatar
Is it possible to tune say only 50% instead of going all the way?
Also, what is the effect on fuel consumption?
Old May 27, 2015 | 01:19 PM
SPONSOR
OE Tuning C63 AMG
Sure, we can always tune for less power. On our performance tunes for gasoline vehicles we typically see fuel economy improvement of 1-4mpg.
Old May 27, 2015 | 09:02 PM
RA7822's Avatar
For a car in the northeast part of the U.S. how do I get a tune?
Old May 28, 2015 | 04:06 PM
nvestr's Avatar
2016 C450 AMG
Could someone simply purchase a second ECU and then proceed to sending it over to you for tuning? In that case, the vehicle wouldn't be out of commission for however long shipping and your tuning takes. Not sure what an ECU costs - I know for my 2016 Acura MDX, an ECU is $300 so I'm guessing it can't be $1000 for the W205 one...
Is there a reason why a second ECU wouldn't work? Is it hard to remove?
Finally, how would a tune like this affect warranty? Would it be something they would find out about and void my warranty as soon as they put the vehicle on their machine? Would they only deny warranty claims that they can prove are caused by the higher boost, etc. of a tune?
Finally, if a person has two ECU's, could one simply revert back to stock before going to the dealer for warranty work?
So many questions, lol...
Old May 28, 2015 | 07:39 PM
SPONSOR
OE Tuning C63 AMG
Remove ECU and send in via overnight shipping for fastest turn around. All ECUs that arrive before 12 noon are guaranteed to be sent back same day as arrival. If you are located close to a flash dealer location that has bench flashing tools then you can have the tune installed at the dealer location. http://www.oetuning.com/dealer-locator
Sure, you will need to buy a replacement ECU through the dealership and have it coded to your car before we tune it. Prices are $1400-2100 usually for MB ECUs.
Old Jun 21, 2015 | 11:38 AM
alika808's Avatar
W211
You guys can repair a bad ECU? If so, please provide us the price range (approximately). Thank you.
Old Jun 22, 2015 | 12:31 PM
SPONSOR
OE Tuning C63 AMG
It really depends on a few factors. What exactly happened that you need your ECU repaired? Can you bring car and ECU into the shop in HB?
Old Jun 22, 2015 | 01:09 PM
l3it3r's Avatar
Veteran: Army
2015 W205 C400 4Matic
If you need an east coast C400.....
Old Jun 22, 2015 | 02:20 PM
LateC300's Avatar
2015 C300
well if you need a bay area c300 tester, let me know.
or when you guys come out with a tune for sale, i see you dont have a w205 c300 tune out quite yet. waiting!
Old Aug 17, 2015 | 08:37 PM
RA7822's Avatar
Why are both line graphs low? Shouldn't the base (blue line) be around 360hp and 370ft-lb at peak?
Old Aug 18, 2015 | 03:33 AM
dreamerak's Avatar
CLA 250
Because they are measuring at the wheels not the crankshaft.
Old Aug 19, 2015 | 02:28 PM
SPONSOR
OE Tuning C63 AMG
Actually these power figures are pretty close considering an average 18-20% drive-train loss for an all-wheel drive vehicle.
The increase in performance on the street after is huge.
Old Aug 22, 2015 | 10:25 PM
C63newdude's Avatar
C63 AMG
That is the way to go.
Old Aug 22, 2015 | 10:31 PM
C63newdude's Avatar
C63 AMG
So you guys are making more than twice on your tune than Renntech..:
https://mbworld.org/forums/c-class-w...tra-power.html
Renntech is making 50hp(crank) and 55lb-tq(crank) but you guys are making:124wTq and +106wHp(to the wheels)
Go ahead, elaborate, I already have the popcorn bucket on my lap
Old Aug 24, 2015 | 01:30 PM
SPONSOR
OE Tuning C63 AMG
Popcorn? This is what was seen at all 4 wheels on a Mainline 4x4 Dyno. The 450 V6 biturbo platform was street and dyno tested thoroughly over a 3-4 week development and testing period.
Old Aug 25, 2015 | 01:26 PM
Crimson110's Avatar
2015 W205 C300 4matic
Any tunes for the W205 C300? If so what are the gains?
