Fix for Wheel Alignment?
Old Jun 13, 2015 | 07:44 AM
c200amgline's Avatar
2015 C200, Petrol RWD
The wheel alignment of my car is slightly to the right and has been for at least a month because I never found the time to fix it. Then I set off to find a wheel shop that will be able to fix it. All said that they did not have the calibration for the 2015 C-Class and only my dealer's service center did, however it costs $435 to fix it... and it shouldn't cost more than $50-100. Unfortunately it is not covered under warranty. Anyone else had the same problem and found a fix?
Old Jun 13, 2015 | 07:51 AM
StanNH's Avatar
2015 C300 Sport: Palladium, Premium, Multimedia, Leather, BLIS
The alignment on my first C300 was off when I first got the car. The first time I had it in for service, I had the dealer correct the alignment under warranty. If it was off when you first got the car, it should be covered under your warranty. After that, you're on your own.
Old Jun 13, 2015 | 08:37 PM
Glyn M Ruck's Avatar
Super Moderator
When you say your alignment is off do you mean the steering wheel is not centered or the car pulls or is wearing it's tyres unevenly?
If steering wheel needs centering Stan is spot on. Dealer must fix under warranty.
Old Jun 15, 2015 | 10:21 PM
vortechvr6's Avatar
W205 C250 AMG
Same here, the steering wheel slightly to the right. Went to a local tires shop. It took them 45 minutes to do the wheel alignments setup and now the steering wheel were dead center.
