Square setup for wheels
Old Jun 22, 2015 | 05:08 PM
zarraz's Avatar
audi s4
I just ordered a c300 and read some threads on aftermarket wheels, a lot of people are going staggered on the wheels, If I wanted to go with a square setup, would a 20x10 fit in the front, basically what is the best size for the front, 20x9, 20x9.5 or a 20x10, as I know all these will fit the rear it is the front I need to know about and the best offset, thanks in advance for the help
Old Jun 22, 2015 | 05:14 PM
jolt8631's Avatar
2015 C220 AMG Line Bluetech.
Will you not end up with the fronts rubbing if you go to the 20 x 10s?
There are a number of threads where folks have gone for 20" wheels, you should do a search.
Old Jun 22, 2015 | 05:31 PM
zarraz's Avatar
audi s4
Thanks I did do a search and most are staggered, and the ones with square setup have 20x8.5 I want to do a nice semi aggressive setup, if 20x10 front fit, what offset would work and tire size do not want to modify the fenders and the car will be dropped 1.6 front on springs
Old Jun 24, 2015 | 11:00 PM
Dkinsley's Avatar
C400
Don't think you can do it.... I did a 20x9 with a 245/30 on the front and 20x10 with 275/25 rear with a very aggressive offset. Though it did not rub it has NO more room. I guess if you made some fender modifications you might pull it off. car has been lowered 1.6 with Vogtland springs.
