Scraped 18" wheels
Otherwise there is a lot of info out there on DIY how to fix curb rash. Some involves grinding with a dremel or using filler compound and repainting. I recommend googling and you'll find more than I can give you here but here is a good article:
http://www.audiworld.com/tech/ext43.shtml
You can buy the matching paint for our wheels online. Good luck and if you fix it let us know.
Easy fix for about a hundred bucks. Looks new when done, at least with the guy I've used. If you're leasing and it's a little scratch like that it's up to you, but you should fix them before you give it back to MB.
The real cost is about $100-120CAN per wheel But the dealership would charge you $200.
its simply stating that while enjoying a pimper ride (with a bigger wheel), these are some of the sacrifices one needs to be prepped as well.
