no more C400!
It's definitely doable.
Besides the four cameras, there is three additional pieces for the each mirror and the front grille, and then a wiring harness for each camera. If you have the rear view camera, some of the parts can be reused; however, the rear camera itself has a different part number.
There is also a control unit, switch block, bracket, and nut/washer assembly. 20 pieces total...something like that depending on what can be reused.
I will most likely give this a go... I wasn't real big on any of the after market setups. If/when I do, I'll probably make a video of the install.
Not sure if a dealer would add this...I can see that being dependant upon the dealer (some might and some might say no). That might come down to your relationship with the dealer.
There are three parts for the front camera that can potential be different between the C400 and C450, one is the grille for sure. The next is the protective grille (which is a piece under the grille) and the last is the housing piece.
