2012 winter rims on a 2015?
2015 C400
Before this great Canadian winter begins to come in..... I want to confirm that the wheels that fit the W204 will fit the W205. Can anyone confirm weather or not it will work or will I need to buy new rims for the W205?
Depends on equipment and engine sizes, for a W205 with AMG Line youll need at least 17", you will also need TPMS sensors and different tires as the W204 use smaller sizes.
2018 E300 Lux, 2006 Corvette Z51, 2015 Mercedes ML350 (wife's)
Here we go again- I also personally tried it- 17in factory recommended dimension winter wheels that fit my C204 hit the caliper on the inner barrel on the W205. I saw it with my own eyes as I was in the bay when the tech tried it. Maybe with spacers and such you could get it to work.
So basically OP, you're going to need to try them for yourself although I see no way of them fitting.
I never said that W204 Wheels would fit, I just stated that 17" in general works using the correct dimensions.
using 17" you will need 8" width with an offset of 45mm.s, the widest 17" front wheel from a 204 is 7.5"
Well he never said anything about stock 204 wheels, for all I know he could have 17x8" aftermarket winters for his 204, then they would also fit his C400
