Airmatic vs sport suspension
I took my c400 in to the dealer for the 2-3 rough shifts and the bermester speaker behind the command that makes a static noise.
They gave me a 2015 c300 with sport package as a loaner and the first thing I noticed is the difference in ride quality!
The difference between the airmatic and sport suspension is immense.
Here the differences I noticed:
- the sport suspension is stiffer than even the sport + setting on the airmatic.
The car is bouncier and rougher but feels tighter.
- the ride on the airmatic is much quieter over rough roads.
- the sport suspension is much more responsive in my opinion and handles better, furthermore, it does not give that feeling of delay on sharp turns like the airmatic gives.
In the end, I must say, I am very glad I got the airmatic because the car feels more like a luxury car but I can see how some would prefer the sport suspension over the airmatic!
My engine light came on, and I also have a loaner, new c300 no sport package, very basic, still elegant with 17" wheels, etc.
The airmatic is the most value for the money option. I had air suspension before and although the wheelbase restricts the ride quality, it is almost on par with CLS or S class.
It's a choice between better handling or better ride quality. There's no right answer, since not everyone is looking for the same thing. I'm in an area where the concept of a straight road is unknown, so I have always preferred a car with very sharp handling .... even at the expense of some ride comfort.
I'm with Stan on this. I don't think one is necessarily better than the other because we drivers are a diverse lot and we have different needs/expectations from the suspension in our cars.
I personally chose to not add the Air Suspension and go with the Sport Suspension. But that was my personal choice. I prefer a firmer/tighter feel and while the C I test drove with the Air Suspension was softer/plusher, in side by side driving, I personally enjoyed the Sport Suspension better.
Air-suspension does smoothen the ride significantly (not completely like S-class but pretty close to it). I felt painful jolts on my back with a standard suspension, and they were all eliminated with the air susp.
1 Post
2015 C400, Steel Grey, 4Matic
Some of that ride quality is due to run flat tires versus non run flats. I've had vehicles with 18 inch run flats and moved to a 19 inch with a lower profile non run flat and the ride was smoother. It's amazing the difference in ride quality between the two.
I for one am glad Mercedes gives it's customers a choice of suspension.
Clearly, we're on the same page! +1
Everyone is different, so yes, no right answer. I ordered non-sport, but the factory put sport suspension on by mistake - I guess. Anyway I hate it. I haven't gone in for a service yet, but when I do I expect a fight when I tell them to give me what I ordered...
BTW, I found out when I did a VIN search.
Just a side note: whenever we discuss suspension characteristics, we should also include tire pressures in the discussion. If you use the pressures given on the door panel, your tires are over-inflated. The numbers inside the fuel door are what should be used, and adjusted for temperature.
I generally run 34 psi all around and find that to be an acceptable balance of ride and handling with the Sport suspension on the OEM 18" run flats.
In this case, both cars ride on 18 inch runflat continentals, however, I neglected to check the tire pressure on the loaner.
I keep my tires at 36psi cold all around.
I opted for the Airmatic on my second car and it rides exactly the way I imagined! I'm so happy that Mercedes offers Airmatic in the C-Class, without it I probably would not have given the model a second chance.
Yes, it was smart move on part of MB to offer air suspension, customers like me (granted they are few
) would not have owned a C. I started my search two months ago my eyes set for an S-class, and here I am today sitting in a C-class ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
My first W205 was a "Sport" w/19"s and I thought the ride was too harsh...I say "Sport" because my car was a Sport pkg car but built with the Comfort suspension. I bought 18"s for my winter setup and the ride got a bit better but still not what I expected when buying my first Mercedes.
