Audio 20 upgrade to navigation?
C 220 Bluetec
Hello everyone!
I was wondering if there is any possibility to upgrade my audio 20 usb to navigation. I did the stupid mistake not to pay attention when I ordered the car at my dealer, telling him that my only preferences are the automatic gearbox and the intelligent LEDs, because I travel a lot and the rest of the upgrades are at his will, with the condition not to exceed 45k euros. It did not cross my mind that I have to tell him that I need navigation too. Well after receiving the car in May 2014, the dealer said that there is no cheap solution anymore, because I have the radio 20 usb and it would be very difficult and expensive to try some workaround ( even more than 4k euros ). Hearing about the outrageous price, I chose to buy a portable navigation, but I don`t really enjoy it so much...
So, after waiting so long, I am asking you guys, if there is any possibility you heard of in the meantime.
Thank you in advance!
C 220 Bluetec
Well they told me sometime ago that it can`t be done, because I don`t have the audio 20 with cd (forgot the code for it) and therefore there is no satellite antenna installed. I have the stock audio 20, only with usb...
Should I try to another dealer?
My understanding is all audio 20 are pre wired for navigation and what you need is to buy the garmin map pilot system for installation. This simply comes on an sd card which is installed in the sd card slot. It means you loose the use of the sd card slot for music but as there are 2 usb ports, bluetooth and of course the old fashioned tecnology of cds it is no big deal. Mine came with garmin map pilot as part of the package and it works well, i shall rephrase that it operates as it should but frankly this is my second mercedes navigation system and it is not their forte....tom tom do it better! However i prefer it to having an add on unit or phone especially as it works with the head up display. My main gripe is inputting destinations but it is complicated by being in france saint or sainte and postcodes which cover several villages but sometimes the routes do include narrower roads which are more diect but much slower.
The full command system with the built in media centre operates differently as it has an inbuilt harddrive and the navigation is downloaded from dvd.
Looking at the accessories catalogue mercedes france sent me last week it costs 647 euro for the card the part no for a c class is shown as A205 906 8502. Methinks your dealer does not know what he is talking about unless cars for your market are configured differently i have assumed you are uk based so think you should be ablemto sort this for a few hundred painful but more doable than thousands!
I have retrofitted at least 10 Garmin systems, it is an easy install, takes about two hours.
You need a new 12V feed cable for the new USB/SD unit, routed from the passenger footwell, a GPS antenna mounts behind the instrument cluster, a longer GPS antenna Cable and the USB/SD slot unit.
Coding of the HU and IC and inserting a Garmin map SD.
goy0 (07-13-2020)
C 220 Bluetec
Thank you all for your answers!
I will try another dealer, maybe they will be more competent, although I doubt that. After all I live in a big city in Germany, the dealer is also a pretty big one, so I expect they should have known if it was possible to make it work just with a card.
@vic viper What you say, makes more sense, because I don`t have a GPS antenna and that`s what the dealer told me too. Unfortunately, I don`t think I`m able to do something like that myself, at least not without instructions step by step.
Now i understand your problem and it seems it is a country specific specification issue ...... globalisation is not so homogenous. Here in france all c class have the audio 20 with cd, 2 usb ports and sd card and are pre wired for navigation i.e they obviously have the gps antenna....so my advice is rubbish sorry! Vic as ever has solved the issue but maybe a dealer could do the work needed for less than suggested by your dealer. At least now you know what the issue is.hope you can resolve the issue to your satisfaction.
C 220 Bluetec
Well, they told me that I should have payed around 100 euros to have the audio 20 with cd. Which is really disappointing coming from mercedes, but what can I say?
No problem, your answer was not rubbish, it`s my fault for not providing enough information.
@ Vic can you tell me a price range for the retrofit?
There is a TS (teilsatz) cointaining antenna, adapter cableand SD-card reader, you will also need the additional feed cable,
also in very early W205 you will need a ground cable, but we are talking around €2 each here![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
The TS is around €300 if I am not mistaken.
C 220 Bluetec
Shouldn`t the dealer be able to do this kind of work? Or should I search for another specialized autoservice? I could try to do it myself, when I`ll have enough time, but I am a little afraid not to mess something up...
If you have some basic skills there shouldnt be any problems, the hardest part is the first step wich is removing the centre console alu trim with the armrest opening button.
Once that is removed it is just a matter of loosening screws and unclipping some panels.
Remove passenger side door sill and carpet lining
Remove centre console
Remove armrest
Loosen the HU
Remove cover around steering wheel below instrument cluster
Remove instrument cluster.
Fit antenna behind instrument cluster, fit extra GPS Cable to antenna (90deg bend), remove Purple housing in other end of Cable, route Cable to HU and insertin free slot of blue connector,
insert the feed wire into the pink connector slot 5 in the lower passenger A-pillar, insert other end into SD-Card reader black connector, next to brown ground wire (cant remember slot number)
Code instrument cluster and HU, insert SD card.
Remove armrest
Loosen the HU
goy0 (07-13-2020)
C 220 Bluetec
It does not sound too difficult, but I will ask the dealer first, if they can do that and what would be the price of it. If they can`t or they will ask again for a high price, I will try to do it myself. I`ve already looked up on the internet and I could not find the teilsatz you are talking about, at least not for the w205. Should I ask the dealer for the TS?
C 220 Bluetec
Ah, I found that TS online sometime ago, but when I check for compatibility with my vehicle identification number it says so:
C 220 BlueTEC
C 220 BlueTEC
- This accessory model cannot be used in conjunction with your vehicle owing to technical restrictions regarding model year, equipment or engine.
Yes, but you also need the 12V Power Cable
The kit includes Antenna and SD card module, you need to buy the SD-card software as well.
W205 220 Bluetec AMG 15' / W202 220cdi Esprit 99'
Why MB parts are so expensive... I can buy card reader for 30euro but cant buy gps antenna so at last i must buy kit from mb ;(
Or maybe you know part number from gps antenna?
I was interested in Audio20 to Comand Unit upgrade. My dealer said its not possible to retrofit due to mercedes isn't supplying comand unit as a spare part. There are some sources about retrofit and also come up with some second hand units but it is too much money to risk without a reliable information.
Louis300 (07-21-2020)
Had this conversation with my dealer today regarding my wife's 2015 A-class with audio 20 cd.
It has the bigger screen, it has a sd card reader slot on the radio thingie and it reads and play .mp3 (just tested) and still they say its not worth it and it will cost me like 5000 euros to fit.. What the hell
It has the bigger screen, it has a sd card reader slot on the radio thingie and it reads and play .mp3 (just tested) and still they say its not worth it and it will cost me like 5000 euros to fit.. What the hell![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
If your car has SA code 522 you only need an additional GPS antenna and some coding.
If not youll need a new head unit and it might be expensive.
I have (505) audio cd with sd card reader and USB connections for my phone.
That is at least what my paper says.
