overhead display installation
Old Oct 26, 2015 | 06:04 PM
saged.hamdy's Avatar
US version C class 2015 sports line
hi All,
i am thinking of installing the overhead display, my car has almost all the options with the exception of the overhead display. i read on some forum that it costs around $900 to install it at any benz dealership so wanted to ask you guys if any had installed it and if this cost sounds right. also wanted to know where will they install the activate button
Old Oct 26, 2015 | 08:59 PM
miketc's Avatar
W205
It cost around $900 as an option so I doubt it will be the same as retrofit. I don't even know if the OEM OHD could be added after delivery. Good option if you could get it. Let us know how it work out.
Old Oct 27, 2015 | 09:40 AM
jolt8631's Avatar
2015 C220 AMG Line Bluetech.
$900 to retrofit - they are having a laugh!
For a start, you will need a new dashboard (the HUD has a massive hole in the top of the dash) - when I got a quote for my E89 BMW, 3 years ago, it was £1800 (€3500) then. Add to that you will need the HUD itself, replacement windscreen, switch and coding - I am not sure if the HUD is driven by a discrete Control Unit, or off another existing Control.
Add that lot together and you are looking at €000s before you add any Labour. If you want a HUD that desperately, it'll probably be cheaper to trade.
Old Oct 28, 2015 | 05:16 PM
parkwood's Avatar
EQE 500 4MATIC replacing EQC 4matic AMG line P
Originally Posted by saged.hamdy
hi All,
Mercedes france accessories catalogue lists an aftermarket hud system for 904 euros for an m class so the c willbe the same it does not show details of where the on off switch is but i wonder if they use the same one as the factory fitted ie on the lh side but if it is abase model there maybe no provision as the base here just has a coinholder.
Your quoted price looks accurate. The system consistes of a unit which sits on top of the dash. They are cheaper now as more after market ones for any car are available just like sat navs years ago! Part no is shown as A166 906 1402.
Old Oct 28, 2015 | 05:28 PM
xMB007x's Avatar
ML350 BTC & C300
Not worth it. I find the digital screen on the instrument cluster to be enough.
Old Oct 28, 2015 | 05:37 PM
parkwood's Avatar
When optioned it was a in for a penny in for a pound decision but i actually find it very very good and much better than looking at the display not least because the scale for kms is a tad congested. Navigation instructions inc a distance countdown in your eyeline while you are also looking at the road work much better and i think it is a much safer system.......but that is the factory fit system. However from the catalogue it looks as if the mercedes add on does connect to the nav system so would be as good unlike some of the cheaper aftermarket sets.
Old Oct 28, 2015 | 10:00 PM
dnice-1's Avatar
C300 4Matic
I found the HUD as a "cool to have" but not a "must have". I found there is nothing it does that the info screen and the dash can't tell you. Half the time I forgot it was even there especially when wearing polarized sunglasses.
Old Oct 29, 2015 | 08:50 AM
miketc's Avatar
W205
Must have for me with Distronics. In addition to the Navigation instructions and car speed, it also display the set Distronics speed.
