OBD2 port?
Old Nov 14, 2015 | 07:50 PM
DBOC205's Avatar
W205 C250BT
OBD2 port?
Is there an OBD2 port on the W205 .. and if so, can someone tell me where?
My yellow engine check light came on yesterday and hasn't gone off since, but there's no other messages.
I've got an OBD2 scanner and was looking to plug it in to see if I could get any fault codes out of the car but can't find a port.
Old Nov 14, 2015 | 08:08 PM
Dasani's Avatar
2020 C63s Coupe, 2016 C63s Sedan
On left hand drive vehicles it's under the dash, from where the parking brake release is follow further under, near the hood release, there's a "cover" on it, just pop it off. I would think it would be mirrored on right hand drive vehicles.
Did you check that your gas cap was tight? That's a common error and easy fix.
Old Nov 14, 2015 | 08:10 PM
DBOC205's Avatar
W205 C250BT
Aaargh.. never mind, I found it (hiding behind a cover).
I've managed to get a P229F code from the reader.
Looks like a trip to the dealer tomorrow.
Old Nov 14, 2015 | 08:14 PM
DBOC205's Avatar
W205 C250BT
Thanks for the tip .. helps to get a torch out to look for the darn thing.
Yea gas cap is on solid - didn't run it out of fuel either, which was one of the items listed in the manual for the light.
Old Nov 14, 2015 | 10:16 PM
Glyn M Ruck's Avatar
Super Moderator
Sounds like a TPS issue (Throttle Position Sensor) on the pedal. Dual channel Hall sensor.
Old Nov 16, 2015 | 09:13 PM
DBOC205's Avatar
W205 C250BT
Nope... turned out to be a failed NOX sensor in the cat converter. It got swapped out today. Hopefully that's it now until next service (he says with fingers crossed).
Old Nov 17, 2015 | 06:33 AM
Cmersu's Avatar
Polar White C200 A Exclusive Premium Business
I had the same fault in April. Yellow light came on and it was the NOx sensor. I had 13000 km on odometer.
Old Nov 17, 2015 | 06:57 AM
vsix's Avatar
JBs C63 PP( wifes car ), Mc Laren Pxx(toy), 2013 Mustang GT 5.0 ( DD ), ML 6.3 ( winter DD )...
lol you know nxt time you post sich an newbie question, it's your turn paying a coffee for us
Old Nov 17, 2015 | 08:42 AM
digitallust_aus's Avatar
W205 C250 Bluetec AMG Line
I had an Engine light a month or so ago, Id done an O2 Sensor apparently..
Old Nov 17, 2015 | 02:04 PM
Super Moderator
Then it stored the wrong code. Strange! Benz does have some proprietary codes but that code is supposed to be in the general OBD area.
Old Nov 17, 2015 | 08:13 PM
DBOC205's Avatar
W205 C250BT
Could have just been my old reader Glyn .. it's a Bluetooth OBD2 dongle; (using TORQUE on Android to interface) which I've had for a few years. I wouldn't be surprised if it's not up to task of diagnosing the W205 techno-Wunderkind .
[Edit].. seems like this lines up though..
http://www.obd-data.com/p229f.html
Old Aug 23, 2018 | 10:36 AM
JeremyH's Avatar
Mercedes AMG C63s Coupe
Where did you find it?
Old Aug 23, 2018 | 02:30 PM
JeremyH's Avatar
Ok, I found it. Anyone else looking for it in a right hand drive Mercedes C Class Coupe 2016 onwards should find it quite a long way back (beyond the bonnet release) and a little to the left. Mine didn't have a cover, but I guess that could be because a garage damaged it at some point.
Old Nov 10, 2018 | 02:45 AM
AMG C43 3LV6's Avatar
AMG C43 3LV6
Wow. Thanks so much. About to break a few plastic pieces as I thought thats where the OBD2 was hiding lol.
Old Nov 10, 2018 | 11:52 AM
JeremyH's Avatar
Glad I could help :-)
