Standard Audio + Iphone and EQu App
This fix presumes your music is local and on your Iphone or Ipod. The app does not process streaming or cloud based files. It also presumes you have an Apple device. (Similar programs are available for Androids)
The EQu app by Elephant Candy is available on the Apple App Store.
When you launch it the EQ is flat:
You create the EQ curve by touching the red line, which creates a control point (a green dot) and then moving it to position. Once you have something you like, it can be named and saved as a preset. This is the curve I got in the W205:
I included the COMAND settings for Treble/Mid/Bass that go with the particular curve in the title of the Preset, in this case Treble at 1, Mid -2, and Bass at 10. Balance and Fade are 0. This curve gives the bottom end more drive and power, and cuts back the harshness of the mids. The little dip at 4k gives the impression of a wider soundstage by pulling back that frequency and leaving more of the directional highs intact.
I'd encourage you to recreate this curve and save it, and then monkey around with it to get a more refined result for your taste and the type of material you normally listen to. If you're not familiar with EQ's, the frequency spectrum, low to high (bass to treble) is represented as the horizontal line. Pushing up the line on the left side increases bass, and the right increases treble. Pulling down in an area decreases those frequencies.
If you get a curve you like but inadequate volume, swiping up from the bottom of the screen drags the entire curve up at once, which increases volume. Feel free to post any questions.
It has the same access to your local library that the native Apple music player has. The files do have to be actually local, not ITunes Match. But if you have actual AAC files on your IPhone this will play those through the custom EQ.
Give it a try and post your thoughts.
Also, watch the volume at first. This can overdrive the door Mids. In Settings (gear icon) under Headroom select "Safe" to start.
however they have a version called Radio EQu...this looks like it will do the same for iTunes Music (which i use) and internet radio by Tunein (which i dont use)
https://support.apple.com/en-us/HT201616
I changed the set up a little. Some material was clipping. This is the curve and COMAND settings when automatic gain (Safe) headroom is selected in the app.
You also need to pay the $2.99 to unlock the adjustable EQ function ( or it stays in a demo mode).
Here's the curve I got:
Meanwhile, I've got a new Spotify subscription.
