C450 Burnout?
Finally, while a non modified AWD car likely won't do a burnout (need lots and lots of power), of course you can launch from a complete stop, that's what AWD usually excels at. Just don't expect lots of rubber burning smoke while the car doesn't move.
This video shows how it works:
in the video, 3 wheels are on rollers and one is on dry pavement, xdrive actually does better in this video..
"“We didn’t just use Mercedes’ all-wheel-drive system. That wouldn’t work for AMG.” So said Ola a few days earlier at a sit down in our office. “Yeah,” chimed in Tobias Moers, the refreshingly blunt head of AMG Vehicle Development. “We completely reengineered 4Matic to make it work for us.” The biggest difference between regular 4Matic and the AMG version is a permanent torque split. In the Mercedes version, the standard split is 45/55 front/rear. However, if conditions change, torque can be moved to the wheels that are losing grip, from 30/70 to 70/30. Not so with the AMG version. Torque is cut 33/67 front to back, and that’s how it stays."
edit: I should add that like many recent awd systems, mercedes uses individual brakes to move power around, which is usually done instead of locking diffs, which should allow the one wheel with traction to get power regardless of the split. This works against doing a burnout by the way.
