Can anyone elaborate this....
Old Feb 15, 2016 | 06:52 PM
darwin329's Avatar
w205 c400 c63s
RE: squeaking sound from the suspension.
"I went to my dealership, and went in to the mechanics. They directly found a issue that's been reported on squeaking sounds from the front suspension. And a special lubricant oil is used. They didn't have time to do it there, so they borrowed me the oil and I lubricated it my self. It is the "rubber stop" or what ever it's called. That prevents the damper to fully compress. So I lubricated it as they told me. And for 2 days it's been good."
I have exactly the same problem now. Can anyone explain what exactly oil/lubricant i can use.. is that how you call it RUBBER stop? thanks guys
Old Feb 16, 2016 | 04:14 PM
topsider's Avatar
2015 C300 Sport 4MATIC
my gti had that when it was cold, apparently it was the rubber bushings
Old Feb 16, 2016 | 08:23 PM
kiet1005's Avatar
Mercedes C400 4matic
Is the squeaking sound pretty bad? I was planning on lowering my C400 within the next month or so with H&R springs. And if you do find out which lubricant is used can you please let me know.
Old Feb 16, 2016 | 10:38 PM
RixC300's Avatar
2015 C300/ 2014 Ford Expedition 2012Ford F205 4x4
There are rubber bushing at the top and bottom of the springs. I used belt dressing with the nozzle and sprayed them. That fixed mine and haven't had the problem since.
Old Feb 17, 2016 | 02:31 PM
blackedbenzo's Avatar
bmw 3msport, 2016 c300 sport amg on order
When I did my spring install I just put some grease on the rubber contacts area where springs touch. No problems with noises for myself. (For reference:Have H&R springs c300 on 20")
I only did that precationarily because I've heard of people having squeak issues. A little grease won't hurt and takes 2 seconds while doing the install.
Old Feb 17, 2016 | 03:24 PM
darwin329's Avatar
w205 c400 c63s
Thanks RixC300!! hmmm can you recommend which brand or any fan belt is okay.
Old Feb 17, 2016 | 04:33 PM
darwin329's Avatar
w205 c400 c63s
hey bro how are you.. i was thinking of spraying with fan belt dressing as per Rixc300.. the squeaking sound is not too loud and i only hear when running slow passing humps/bumps or sloping road then i hear the squeaking sound when the car bounce. right front side only.
Old Feb 17, 2016 | 04:36 PM
darwin329's Avatar
w205 c400 c63s
its not so bad. only when the car bounce on a very slow speed on humps/bumps. if you start turning your music on theres no way you can hear it even the dealership can't tell if theres squeaking sound or not.. but i drive it everyday so i know hehe..
