Bluetooth connection to 2 phones (multipoint)
Hi, I am picking up a new c250 next week and haven't found a solution that will allow me to pair my 2 mobiles (work and personal) at the same time.
I have a Jabra Streamer kit that uses a 3.5mm Aux jack to get calls and music streaming through the stereo but I can't find the jack. Thus also let's me make and receive calls from either phone.
Has anyone found a way to have a 2nd phone paired at the same time to their command system?
Thanks in advance.
Thanks in advance.
Thanks in advance.
Thanks in advance.
I have Comand and it only allows to be connected to one phone at the time. You can fairly easy switch between active phones but this can only (according to the manual) be done when there is no active call.
I have a Jabra bluetooth earpiece that can handle 2 devices at the same time, but that switches as soon as the other phone makes a sound (ie.a bleep from an app) and i would not want my car to switch to the other phone just because a message came in.
The 3.5mm aux jack is located under the armrest. But i don't know if you can use that for phonecalls. My guess would be that it is not possible.
Regards,
Gerrit
